help with wheelie bars
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: help with wheelie bars
    Posted: 28 Jun 2011 at 9:41pm
I would like make up a set of wheelie barts for my wd45 that could easily be taken off and on. Does anybody have a good set up for this ? How about some Pics? Thanks for any ideas, JM
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2011 at 10:08pm
I built a set 6 or 8 years ago for a pull that got canceled. I bought a set of junk fenders and used the mounting plates, the only bad thing is I cant use both the wheelie bars and the fenders at the same time. I welded tube steel (roughly 2"x2") to it with a smaller tube inside, that will adjust for different height tires. I may be able to get some pics if I remember where I have them at.
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2011 at 8:46am
Where are you located ? I had Phile Brown from farley iowa buid mine. bolts to where the lift arms aratch to the rear end.
Spanky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spanky Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2011 at 11:56am
It seems that I am having some difficulty finding a set of Allis Chalmers wheelie bars fo a 1939 WC on steel wheels.  Can you direct me to the individual that helped get you set up?  Any help you can give to get me into the bars would be appreciated.  Thanks, Jeff
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2011 at 4:50pm
I need to bring them back a bit farther but I'll do that this winter. This is on my 45 WC
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2011 at 4:51pm
But I have tested them and they do work lol
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spanky Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2011 at 9:58pm
By any chance are you the guy who makes these?  Will the wheelie bars sustain the raising of the tractor with a jack being used under the sand pad of the wheelie bar? Is that metal stock solid, or tubular?  If you make these, can you do it in a telescoping version? Thanks for getting back to me so quick.  Jeff
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2011 at 6:17pm
i can make the wheelie bars, the set in the pic was aset i made for feilds,they are tubular and telescoping and they wil raise the tractor with a jack
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2011 at 7:00pm
i will sell this hitch wheelie bar set up  for $500 obo . Need to check rules some rules do not like these hitches.
also have a diesel 45 rear end for 500  1st and 2 gear is good . been pulling 3rd with it and its jumping out last time pulled.
This page was generated in 0.044 seconds.
