D15 head gasket
wf32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wf32 Quote  Post ReplyReply Direct Link To This Post Topic: D15 head gasket
    Posted: 19 Oct 2011 at 8:25am
A freind is rebuiling a D15 the head gasket that was shipped didnt have any fire rings in it. Called three different vendors all had same gasket without fire rings. So gasket installed ran 1 hr started missing burnt out head gasket between cylinders. Called vendor back cant get any other gasket from them. Finally found gasket with fire rings and installed know ok. Any one else have this problem
Phil
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2011 at 8:28am
Fell Pro has fire rings. I put one on the little pink puller and it is good.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2011 at 8:29am
Very common with the 160 engine. Buy the Fel-Pro with fire rings. It will stop the problem with proper installation and torque. HTH Tracy Martin
wf32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wf32 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2011 at 8:46am
Thanks  guys the gasket is a Felpro thats in it now
Phil
