Re-Engine Early HD6 G Shovel |
orangeman
Orange Level Joined: 12 Sep 2009 Points: 1710 |
Posted: 16 Sep 2011 at 5:15pm |
Guys: Can a later AC 7000 Direct Injection Turbo be bolted into place where the original Buda 344 block was? The machine I am looking at with the dead 344 is a 1957. I know the 7000 engine had the AC badge on it and came with a turbo at a later date.
Will all the controls, throttle easily interchange? Any advice would be great. Got our first frost last night. Anyone on here down the swap? I believe that some of the 7000 engines where hooked up to military generators.
Danny NM
Silver Level Joined: 28 Dec 2009 Location: New Mexico Points: 69 |
hello i just finished a repower with the 7000 series engine into a 1956 HD6. it went pretty smooth with the help from this forum. i got the engine from bob Kcgrain. had some clearance problems with the fan,oil filter,starter and hood. still working on those but it is running and working good. one nice dozer Danny
superchief
Bronze Level Joined: 16 Apr 2011 Location: Missouri Points: 33 |
Hi Orangeman, We have successfully put a 7000 series engine into a HD6G highlift, a lot of work but it runs fine. We had to take Bosch injection pump off the original engine and change the cam gear, the 7000 emgine had two gears with a smaller gear for the Stanadyne injection pump. There was starter clearance problems with the turbo oil supply line, and also had to use shorter oil filter cannister. ]
We purchased a military surplus engine which did run power generators in the service. We changed all the parts from the old 6000 engine that we needed..
The old tractor runs good and has a lot of power. Have a good day. Superchief
Mactractor
Orange Level Access Joined: 20 Jun 2011 Location: New Zealand Points: 652 |
Heya Chief, is your Bosch pump squirting fuel into the 7000 at the 6000 engine calibration (as you took it off a 6000). Also, where did you set your fuel timing? Manuals tell us to time loader engines at 32 degrees BTDC. A lot earlier than tractor/dozer setting of 28 degrees. Mac
superchief
Hi Mac. We are using the original injection pump off the 6000 engine, we didn't change anything regarding fuel calibration. Set the timing at 32 degrees which is the same as was on the 6000 engine. That also is the setting called for in my book. Hope this answers your question. Have a great day, Superchgief
superchief
Mac, disregard the spelling of superchief on my last post to you. I didn't catch it, Superchief
Mactractor
Thankyou Superchief. I got one of the military 7000 engines to put in a 6E dozer. Have been wondering wether to set timing at 32, 28, 0r somewhere in between. Mac
orangeman
Guys: Very good information. Wish I could have got back sooner, but been on the road.
Know if I could find a gen set 6000 or 7000 engine to put in for the old dead 344. Thanks again guys. Orangeman
superchief
Hi Mac, I don't know if this will affect you or not, but we had to change to the original oil pan and change the sump screen because we have a hydraulic clutch. Also if you use the lower metal cover protecting the oil pan there is a clearance problem, particularily on the hilift model. Have a good day, Superchief
Mactractor
Thanks Chief. I had anticipated having to change all those things. A lot of work but I guess it will all seem worthwhile when she lights up
Dozer
Orange Level Joined: 16 Aug 2011 Location: SW New York Points: 689 |
I am rebuilding my HD6G with the original HD344 engine. The last rebuild I did was another HD6G with an AC 6000 engine. There are several improvements on the 6000 & 7000 engines that make the later engines better. The thing I particularly do not like about the HD344 is that the accesory drive belts drive off the crankshaft pulley so you have to remove the oil pump to change the v belts. I have been looking for new v belts for this engine without success for 2 months. I was unable to bend clasic "C section" belts into position.
I have an HD7G track loader looking for a good home. Location Allegany County, NY |
Mactractor
Gates and Dayco make the correct belts for all the tractor dozers. I`m sure they will do them for loaders
Dozer
The generic equivilent of the V belts are (2) CX56 and one CX48 These are cogged belts. The nearest cogged belts listed are CX57 and CX50
I have been unable to find anyone who can get them. |
orangeman
You know what guys, there is a lot of good information here. I am thinking that if we put together a numeric list of changes that would be needed to put the 6000 or 7000 engine in place of the old tired 344's it would allow many HD6's to live on. Superchief, Mactractor and Danny, all had some good comments and ideas.
Any other ideas, comments or suggestions are welcome. Thank -you Orangeman
Mactractor
Boys, the correct v belts for the crawler engines are automotive A section. The angle of the V is different to that of industrial belts like B and C section. Any of those industrial belts that fit will drive everything ok, but because of the slightly different V angle, will premeturely wear your pulleys, and we know they aint dime a dozen. I will look up Gates or Dayco numbers and come back. I am sure the belts for 6G and 7G are the same as HD6 tractor dozer. Mac
Mactractor
Numbers off HD6 tractors in my yard (fan belts); Gates 20A 1295 (13/16 X 51). Dayco 74349715 42-0399. Water pump/generator belts are 15A (5/8) but cant read the length
orangeman
Mactractor - Excellent information this helps a lot for those that love the Orange Track loaders and Crawlers.
