WD Stuck In Gear
Tim in MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim in MN Quote  Post ReplyReply Direct Link To This Post Topic: WD Stuck In Gear
    Posted: 14 Sep 2011 at 5:34pm
I was out plowing the garden today when the WD got stuck in gear, can't shift into neutral.  It has shifted hard since I've owned it, so I pulled the shift tower, the trans gears look good and slide like I think they should.  Pulled the shift lever out, 2 snap rings, washer, the shift lever pin is ok, not much play, but I don't know about the lever end.  The service manual has no decent picture of it, couldn't find a picture of one during a search here.  Anybody have a picture of what of a correct shifter end they could post.  Anybody sell rebuilt shifters, I have no welding capabilities.
        TIA,  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2011 at 5:55pm
Somewhere in the archives on here was a diagram of the size and measurments of the end. might look for a friend that can weld or local shop where they can build it up for you.
stu(ON) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2011 at 6:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2011 at 7:12pm
Across the flats it should be about .315
Across the ball is .530
These dimensions I got from an earlier post but I didn't save the post address just the
picture.
Edited by CTuckerNWIL - 14 Sep 2011 at 7:13pm
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2011 at 7:38pm
That's pretty good, in a little over two hours you have some great pictures and a drawing with dimensions. Way to go team!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim in MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2011 at 8:41pm
Thanks guys, I'll see if I can find a place to get it welded up.
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2011 at 5:23am
check with Bill at Sandy Lake Imp.
Seems like he told me they will do it.
Dennis IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2011 at 5:32pm
I had the same problem quite a few years ago. I would take the whole shifter assembly off and slide the gears into netural and and get the shifting forks realigned and put it back together. That would last for as long as I was remembering to shift very gently but soon enough I would forget and it would happen again.
I finally got tired of doing that nonsense and got a whole diferent shifter assembly from a salveged parts WD and haven't had a problem yet and it was a lot easier than building up the shifter end.       Dennis.
