unleaded gas vs ethanol |
Page 12> |
Author | |||
tractorman ![]() Orange Level ![]() ![]() Joined: 22 Sep 2009 Location: west central wi Points: 1046 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Sep 2011 at 9:12pm |
until now i have been able to buy gas with neither lead nor alcohol, now my service station is saying there will be no more gas without out ethanol. my equipment is all older and i kinda felt safe from the stories of ruined engines especially in small engines like mowers and chainsaws. What am i to do lead substitues, stabil other additives?. As long as they work i enjoy using my older equipment and am happy with it
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
Sponsored Links | |||
DanD ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: WI Points: 856 |
I have never had a problem with small engines and/or antique equipment or my newer automobiles using 10% ethanol gasoline. I wouldn't worry a lot about it. I don't know where exactly in West Central Wisconsin you are, but Kwik Trip stores have no ethanol gasoline in their high octane gasoline. Doesn't cost much more for the small amount that little engines use.
I've been using ethanol in everything I own since it was available at the pump, many years. The only thing I had trouble with that might be attributable to the ethanol, is the gas line on my 20 year old Ryan weed wacker dissolved. Maybe it was just too old. I'm sure if I replaced the fuel line, I could get it running again.
Jeff Z. NY ![]() Orange Level ![]() Joined: 11 Sep 2009 Points: 7326 |
Some small engine companies are now saying to use the middle grade gas in their engines.
No problems so far with the tractor engines. |
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88173 |
I bought a new F250 in 1989 and started buying ethanol in central illinois at that time. I have used it in the mower, weedeater and several B tractors and the D17 for 20 years. No problems.
Most small engines have had Stellite exhaust valves and seats for decades. About the only problem with ethanol blends is they usually will have a shorter shelf life vs straight gasoline. I do put Stabil in my gas engines that don't get used often.
jccleav ![]() Orange Level ![]() ![]() Joined: 11 May 2011 Location: Indianola IA Points: 211 |
Ethanol will act like a cleaner. I have seen it cause problems in older vehicles where the fuel filter gets plugged. Ethanol burns hotter the straight gas. Every small engine mechanic I have talked to said not to use ethanol. That being said, I have used ethanol in a variety if engines without an issue.
mdtractormechanic ![]() Orange Level ![]() Joined: 26 May 2011 Location: MD Points: 662 |
You may want to view these links:
Joe's 1939 Model WC, 1940 Model RC, 1944 & 1950 Model C's, B-125 PU
bwp ![]() Orange Level ![]() ![]() Joined: 02 Oct 2010 Location: Elko, NV Points: 500 |
Ditto on the articles posted by in mdtractor. Here in CA it's already 15% ethanol. I got worse mileage in my 74 Roadrunner and 1970 F250 with the low grade 15% ethanol/gas. Worse mileage and poor shelf life, means more money from state and federal gas taxes. I use 89 octane now. Especially use Stabil in 87 octane for smaller engines. Just my experience.
Brad |
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
In any engine that I run often I've had no problems but anything that sets a while I may end up cleaning the carb. I've been buying the non ethanol gas at Fleet Farm for my tractors and small engines with no further trouble except that Fleet Farm is 20 miles away so in a pinch I still end up using the crappy ethanol from the country gas station down the road.
Wink I am a Russian Bot |
MUM FARMER ![]() Silver Level ![]() Joined: 12 Sep 2009 Points: 95 |
Its junk!!! eats up anything rubber or plastic poor shelf life aluminum carbs will start to grow barnicles because the alcohol attracts moisture like a magnet the biggest problem is the fact if not treated it wont last 6-8 months
Rogers ![]() Orange Level Access ![]() ![]() Joined: 16 Sep 2009 Location: Georgia Points: 2176 |
You haven't been able to get regular leaded gas for 30 years at a gas station, so being unleaded isn't a problem. Ethanol gas isn't a problem from a standpoint of running and everyday use. The problem with Ethanol gas comes from sitting in carburetors. Ethanol attacks rubber seals worse than gasoline without Ethanol.
Edited by Rogers - 14 Sep 2011 at 6:44am |
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
I for one shut off the gas and drain the bowl if it's going to sit for more than a week. If I can't drain the bowl I let it run until it dies. No problems here.
1957 WD45 dad's first AC
TexasAllis ![]() Silver Level ![]() ![]() Joined: 14 Sep 2009 Location: Texas Points: 396 |
Run premium in the small engines. My mowers, chainsaws and weedeaters run nothing but. Back when I was in the hardware business I had many a rep tell me to run the best gas I could get.
Dave Richards (WV) ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Fairmont, WV Points: 881 |
I have only experienced two problems with ethanol. It ate up the fuel line on my D14 and filled the carb with little black rubber "clinkers". I am slowly replacing all of my fuel lines with metal ones. The other problem is the rubber tip on most newer needle valves. Ethanol softens the rubber and they stick. If the D14 sets longer than a week or so, i have to unfasten the fuel line at the carb and give it a 30 PSI enema.
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 42003 |
In any of my motorcycles the ethanol runs fine so far but it sure makes a mess of the pot metal carbs if it sets for long in the bowl. Plan on spending a lot of time cleaning them .On one mower the same problem the carb became junk. Had chain saws that would not run after setting a month with gas in them, dump out old gas and put in fresh and start right up.
Anything that will set for more than a few weeks should be drained and carb ran dry.
427435 ![]() Orange Level ![]() Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
The vast majority of majority of the bad things you hear about E10 is old wives stories. However, there are 3 things it can do that will cause problems.
1. If your fuel tank (or gas storage tank) has accumulated water over time, the E10 will absorb it and lead to a lean condition on carbureted engines------to the point of missing and not running. Once the water is out of your fuel system, the E10 will keep it out if you regularly use it. 2. It is a solvent and will remove varnish buildup in your fuel system. That can lead to plugged fuel filters and carburetors. 3. It can dissolve some old fuel lines and rubber parts (however, old fuel lines may fail even without E10) That being said, I've been using E10 in the following for 12+ years without incident: 1960's McCulloch chainsaw 1967 Corvette (with 3 carbs) Allis B10 garden tractor 1977 IH Scout 1977 boat with a Mercruiser I/O (6 cyl. Chevy engine) 1985 Allis 917 garden tractor 1980's Simplicity GTHL-17 garden tractor 1990 Scag with a 20 hp Kohler 1990's string trimmer And a number of newer cars with fuel injection. I use Stabil in the cars and boat, but don't bother with the small engines. Works for me. |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
Byron WC in SW Wi ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Wisconsin Points: 1635 |
I burn mostly diesel/biodiesel. The gas sits in my WC for months at a time and I Haven't had a problem yet but I try to keep it full so water doesn't get in it. I'd do that with gas or diesel too. The only thing I burn non ethanol gas in is my smaller engines like chain saws and weedwackers. I burned ethanol for a long time in those engines without a problem but I heard that you shouldn't use ethanol in them so I don't. For the 4-5 gallons a year I burn through them it's not a big deal.
This Isn't a wives tale. As a mechanic I've seen the damage sited in the articles. People replace parts on small engines thinking it's just part of aging. Infact, many of these components have failed due to the ethanol content. Bottom line is that it shortens component life whether you notice it or not. Yes, you can do all the little prevention methods and temporary fixes but why should you have to. Edited by mdtractormechanic - 14 Sep 2011 at 10:01am |
Actually, it's mechanics tales, not old wives tales. They often blame the wrong thing for the failures they see. All the fuel lines and carbs on my engines are fine after 12+ years of E10. Explain that. |
Mark
KY ![]() Silver Level ![]() Joined: 08 Dec 2009 Location: Kentucky Points: 371 |
Not sure if stations use it here in KY or not, probably so. Makes me a little leary about the quality of the gas in my bulk tank. Ive seen Lucas gas additives for ethanol gas, may pour some in the bulk tank for a safegaurd. |
I posted the links for people to make their own chooses and to give them the benefit of what I've seen over my 30 plus yrs. I didn't routinely work on autos but heavy equipment where engines like farm tractors are usually pushed to the limits. If you read these links, I don't think you would be so ready to insult mechanics but I could be wrong.
KY, ethanol absorbs water and that is the number 1 problem with longterm storage. I believe the shelf life is 3 to 4 months. Even if the tank was water free it absorbs the moisture from the air. That's the nature of alcohol. We used alcohol in diesel machines to help burn off the water in the tanks. Be carefull of additives that claim to 'remove' water from the tank.
Rawleigh ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: White Stone, VA Points: 421 |
I have had fuel lines turn into bubble gum and the bowls of carbs rusted and/or with white crystallized white deposits in the float bowl. Also gas tanks rust badly with it. If the engine is run at least weekly you will probably have no problem. otherwise hang on to your hat!!
So is there anything you can add to the gas in a bulk tank to keep it longer? Pretty expensive investment that could ruin.
I'm sure there are more knowledgeable people here that can help. The only thing I know is if the fuller the tank the less likelihood of contamination by condensation but I guess that's not practical for bulk storage.
By the way, is your tank metal or non-metal? Edited by mdtractormechanic - 14 Sep 2011 at 3:28pm |
Josh(NE) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Nebraska Points: 514 |
I'd try the Lucas additive because they have some of the best products out there. My younger brother is a small engine mechanic and was just at a kohler school, the kohler guys say with almost every engine problem, ethanol could be responsable for it.
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake |
If the equipment has a separator that's great. Much of the heavy equipment I've worked on over the years had no such device. Some amounts of alcohol put in the fuel during winter to eliminate the water from freezing was a common practice. Small amounts had little if any affect on diesel's lubricating properties. And oviously, if there is to much water you would have to drain and flush the system and find the source of the fuel's contamination.
I could site many more internet source from the UK and Australia. I could copy the info from my service manuals and post them but I don't think it would do any good. Many people are going to have their own opinions regardless. I'm finding that trying to be helpful on this site has it's drawbacks.
You take umbrage at my comment about mechanics tales, but using alcohol in a diesel engine to get rid of water is an excellent example. Mechanics have been know to do things, based on word of mouth instead of actual technical knowledge--------things that can go badly. As far as storage life, when I listed the things I run E10 in, I didn't mention any of my fuel injected vehicles. One of them is a motorhome with a Ford V10 and a 70 gallon gas tank. Every November, it gets stored with a full tank of E10. Every May, it fires right up and runs fine. I do use Stabil in the tank, but that would be necessary even with "pure" gas (Stabil was "invented" long before E10 came into being). Edited by 427435 - 14 Sep 2011 at 11:36pm |
Mark
Page 12> |
