wont shut off
wd45gto View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wd45gto Quote  Post ReplyReply Direct Link To This Post Topic: wont shut off
    Posted: 24 Aug 2011 at 5:07pm
have a wd45 that wont shut off when i turn off the key. put a new switch and does the same thing.thought i hooked it up the same way but really have no idea now.already killed one battery dont want to forget to unhook again and kill another one. thanks for any help
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 7:42pm
Has the generator been replaced with a alternator? If it has then you need to get a diode and put it in the wire that goes between the key and the alternator. My bother-n-law had one that did the same thing. Talked to my starter and alternator rebuilder he had a dioide adaptor that plugged in to the alternator and the plug for the alternator plugged in to it, I think it was $10 or $20.
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote wd45gto Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 8:19pm
thank you ! i will try it
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 8:53pm
I bought one of those alternator plug ins with the diode from this supplier and it's 2 years old and working great.
Danny
Here is the link:
Danny Raddatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote wd45gto Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 3:05pm
well i bought one from the link and installed it.....still wont shut off!!!!!!
i believe it is installed right.now what ???
Flint23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 3:28pm
sounds like your coil wire is connected to the wrong side of the ing. switch leaving it hot all the time.
been there done that, not doing it again...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 4:48pm
Follow the wire from the coil back to the ignition switch and remove it keeping track of where it was connected. Now check that connection with a multimeter to ground and see if it has power all the time. If so, you need to find a connection on the switch that only has power when the key is at start and on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wd45gto Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 3:31pm
thank you all for the help. im happy (and somewhat embarrassed )to report the coil wire was on the wrong terminal of the switch.it shuts off now!! plus i learned something so i guess all is good :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 3:33pm
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 3:41pm
Your not the only one to have learned that lesson. Of course, I've never made that mistake. Oops, maybe I told a little white lie.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 4:27pm
But aren't you glad it was something simple. Good to see you got it fixed.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 6:14pm
well...you could shut the key off, then sit on the exhaust pipe and choke it dead!
This page was generated in 0.477 seconds.
