wont shut off |
wd45gto
Bronze Level Joined: 25 Sep 2009 Location: SE michigan Points: 4 |
Posted: 24 Aug 2011 at 5:07pm |
have a wd45 that wont shut off when i turn off the key. put a new switch and does the same thing.thought i hooked it up the same way but really have no idea now.already killed one battery dont want to forget to unhook again and kill another one. thanks for any help
stray
Orange Level Joined: 16 Aug 2011 Location: Tipton, Missour Points: 323 |
Has the generator been replaced with a alternator? If it has then you need to get a diode and put it in the wire that goes between the key and the alternator. My bother-n-law had one that did the same thing. Talked to my starter and alternator rebuilder he had a dioide adaptor that plugged in to the alternator and the plug for the alternator plugged in to it, I think it was $10 or $20. |
1969 190XT series 3
wd45gto
thank you ! i will try it
dannyraddatz
Orange Level Joined: 12 Sep 2009 Location: Plainfield, Ill Points: 848 |
I bought one of those alternator plug ins with the diode from this supplier and it's 2 years old and working great.
Danny Here is the link:
Danny Raddatz
wd45gto
well i bought one from the link and installed it.....still wont shut off!!!!!!
i believe it is installed right.now what ??? |
Flint23
Orange Level Joined: 31 Jan 2011 Location: New Haven In Points: 429 |
sounds like your coil wire is connected to the wrong side of the ing. switch leaving it hot all the time. |
been there done that, not doing it again...
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22823 |
Follow the wire from the coil back to the ignition switch and remove it keeping track of where it was connected. Now check that connection with a multimeter to ground and see if it has power all the time. If so, you need to find a connection on the switch that only has power when the key is at start and on.
wd45gto
thank you all for the help. im happy (and somewhat embarrassed )to report the coil wire was on the wrong terminal of the switch.it shuts off now!! plus i learned something so i guess all is good :)
CTuckerNWIL
Bob D. (La)
Orange Level Access Joined: 12 Sep 2009 Location: Louisiana Points: 25529 |
Your not the only one to have learned that lesson. Of course, I've never made that mistake. Oops, maybe I told a little white lie.
Flint23
But aren't you glad it was something simple. Good to see you got it fixed.
SHAMELESS
Orange Level Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
well...you could shut the key off, then sit on the exhaust pipe and choke it dead!
