Allis front end on truck
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Topic: Allis front end on truck
    Posted: 31 Aug 2011 at 12:10am
I found this ad and just had to post it here.  Its not my ad.  I have never seen the front of an Allis Tractor for an older truck front end.  I think it looks good.  Here is the link:
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 5:49am
Suppose that radiator is enough to cool a 350?
jccleav View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jccleav Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 8:00am
I liked the back window. I am also a Chevy guy.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 5:38pm
That radiator is probably more suited to it, than many newer radiators... it isn't, however, probably well suited to the pressurized-system application... <shrug> gotta try it to be sure.
What would make it COOL... is if he had a set of B/C/CA front wheels with tri-ribs on the frontend... and a turbo'd 406 underhood...
And a hand-clutch... and a 3-point and PTO stickin' out the back!!!
Edited by DaveKamp - 31 Aug 2011 at 5:39pm
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 5:54pm
The radiator is probably the same size as the original. They normaly only. use the grill shell. The hood is Ford.
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 11:30pm
A guy in town has the front half of a M Farmall on a truck back end. All fixed up with a nice flat bed on it. it has a wide front end but still utilizes the original motor. Don't look to bad.
This page was generated in 0.048 seconds.
