170 gas engine questions |
Darb210 ![]() Orange Level ![]() ![]() Joined: 10 Jan 2011 Location: Ohio Points: 883 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Aug 2011 at 10:33am |
Hello, just bought a 170 gas, clean little tractor, but dropped a valve, owner decided not to fix it & I bought it. Head is ruined as well as one piston. I have a good wd45 engine , is that a feasible swap or will I be under-powering the 170? Any opinions/options are appreciated. Thanks, A.J.
wi50 ![]() Orange Level ![]() Joined: 24 Sep 2010 Location: weegieland Points: 1010 |
the 170 is a much nicer engine compared to the wd45, but you are in luck. Swap the head. Hopefully you can find a piston or cylinder assembly without haveing to buy a complete set if the others are good.
The 170 has quite a bit more power than the WD45, but it needs it with more accesories and hyd to run.
I don't put much time on any of these old gas tractors, it would be nice to spend all kinds of money and have everything fresh, but I usually just repair my "old tractors" to be in working order, if it's questionable than it gets replaced but I don't go putting to much in them. They get driven into the shed anyway untill the battery goes dead and the gas gets old, then I decide to try and use it to rake some hay or run an auger so I can spend more time and money getting it running again.
