d17 alternator
vyvyjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vyvyjim Quote  Post ReplyReply Direct Link To This Post Topic: d17 alternator
    Posted: 30 Jul 2011 at 4:16pm
I'm having charging problems on my series IV D17.
Should I see if I can get the generator fixed or put an alternator on?
If the answer is an alternator, which one and does the positive ground system make a difference as to the alternator?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2011 at 4:23pm
If your wiring is up to par, the simplest thing to do would be repair the generator.  Many times a good cleaning and replacing the brushes and maybe a bearing and it's good as new.
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2011 at 9:57pm
From experience, the new regulators aren't the quality they used to be. My local generator repair shop worked with me and we've developed a transisor and diode setup and mounted it into the original regulator. This has really worked great so far, smoother regulator control and still looks original
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2011 at 10:53pm
Yes the ground does make a difference. If you don't want to switch to - ground you can get a + ground alternator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2011 at 9:29am
I vote for fixing the generator.
