201 engine
one54dodgetruck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Topic: 201 engine
    Posted: 25 Jul 2011 at 12:21pm
Where can i find the brass screen thats tied to the oil pickup? I found some aluminum window screen but would like to use the brass!
Thanks
Andrew
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2011 at 12:51pm
do you know what it looks like? I have a pretty big piece that I saved but don't know if it is what you need. it is pretty fine. I don't even know what size piece you would need. If it isn't to big and isn't to fine I could probably mail you a piece in a standard envelope.
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2011 at 1:27pm
Its just like the screen on your house windows but is brass i might beable to save mine, it has a small tear because i sat the motor on the ground for a moment and it made a small hole. Im going to finish the engine today, so seeing if anyone has an idea where to buy it? Tryed the local hardware stores, but nothing found.
Andrew
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2011 at 5:01pm
well mine is finer then house screen. It is probably the kind those dope smokers would want.
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2011 at 6:03pm
I grabed some aluminum window screen and plan on using a few layers.
Andrew
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2011 at 6:16pm
I would look for a piece of stainless steel. would be cheaper than brass and a lot easier to find. And a little tougher then aluminum.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2011 at 6:52pm
I would also try the stainless idea, remember part of the reason for brass was stiffness.  When the oil is cold, the pump will colapse anthing like screen door stuff, or most anything made out of aluminum.
HTH
Still in use:
This page was generated in 0.150 seconds.
