201 engine |
one54dodgetruck
Joined: 25 Jul 2011 Location: Chehalis, wa Points: 399 |
Topic: 201 enginePosted: 25 Jul 2011 at 12:21pm |
Where can i find the brass screen thats tied to the oil pickup? I found some aluminum window screen but would like to use the brass!
Thanks
Andrew
2 WDs
B B112 D14 D15 shuttle 180 185 7040 Hd7w D14 D15 185 7040 pd |
junkman
Joined: 02 Mar 2011 Location: Nevada, MO Points: 355 |
Posted: 25 Jul 2011 at 12:51pm |
do you know what it looks like? I have a pretty big piece that I saved but don't know if it is what you need. it is pretty fine. I don't even know what size piece you would need. If it isn't to big and isn't to fine I could probably mail you a piece in a standard envelope.
one54dodgetruck
Posted: 25 Jul 2011 at 1:27pm |
Its just like the screen on your house windows but is brass i might beable to save mine, it has a small tear because i sat the motor on the ground for a moment and it made a small hole. Im going to finish the engine today, so seeing if anyone has an idea where to buy it? Tryed the local hardware stores, but nothing found.
Andrew
2 WDs
junkman
Posted: 25 Jul 2011 at 5:01pm |
well mine is finer then house screen. It is probably the kind those dope smokers would want.
one54dodgetruck
Posted: 25 Jul 2011 at 6:03pm |
I grabed some aluminum window screen and plan on using a few layers.
Andrew
2 WDs
junkman
Posted: 25 Jul 2011 at 6:16pm |
I would look for a piece of stainless steel. would be cheaper than brass and a lot easier to find. And a little tougher then aluminum.
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 25 Jul 2011 at 6:52pm |
I would also try the stainless idea, remember part of the reason for brass was stiffness. When the oil is cold, the pump will colapse anthing like screen door stuff, or most anything made out of aluminum.
HTH
Still in use:
