916H
TGerber View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TGerber Quote  Post ReplyReply Direct Link To This Post Topic: 916H
    Posted: 17 Jul 2011 at 9:14am
Hi All, I have a new to me 916H that I mow lawn with, when i got it I did not notice any oil leaks, now after using it several times it has developed an oil leak. it appears to be coming frm the upper rear part of the motor. Can anyone guess/diagnose where it would be coming from ( from past experience with these cast kohler motors)? I am assuming it is a seal/gastket issue. Has anyone repaired one like this recently? I am just looking for some repair advice and possible cost involved. Thanks.
Terry
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2011 at 11:03am
On the 917 that belongs to a lady I cut grass for, that Kohler leaks from the front saft seal. The man that repaired it said it was because the crankcase breather was not clean, thus the pressure forced oil out of the seal. I don't know anything about Kohlers, just passing along the info in case it helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TGerber Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2011 at 12:47pm
Thanks John, After looking at mine again it may be leaking from there, I'll clean it  and see if that makes a difference.
