broken bolt removal UPDATE
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Topic: broken bolt removal UPDATE
    Posted: 15 Jul 2011 at 11:13pm
On my WD, the rear bolt on each of the hangers for the drawbar support have been broken off flush with the bottom of the transmission, and I have put off dealing with them until I started pulling the last couple years. Just wanted to get some opinions on how to approach the removal of said bolts. There is absolutely no thread sticking out below the hole, and I am not sure if they are rusted in, but I'm sure they're hardened and a pain to drill laying under the tractor. This may be interesting.
UPDATE: got one bolt removed by drilling out center and using square bolt extractor, no rust on bolt, pretty good crack when it broke free though. But on the second bolt, I broke a small drill bit off in the bolt after drilling about 1.5" deep, have a nice bigger hole drilled up to broken bit now but bits just quit cutting even when sharpened. Tried welding a nut to the bolt before drilling but didn't work. Should I try a left-hand drill bit? I am just about at wits end here.
Edited by Bill_MN - 25 Jul 2011 at 10:50pm
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2011 at 11:19pm
You might be suprised about the hardness of the bolt, I had 3 broken one in my C when I tore the tranny, final drives and rearend apart and they all came out fairly easy. One was broke off flush but it came out with an easy out. Only one of them had to be drilled out completely and retapped.
Waukesha B, B, IB, G, styled WF, D17, 615 backhoe, 2-Oliver OC3's, 5 Ford Model T's, 3 Model A Fords, 34 Ford coupe, 57 T-Bird
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2011 at 11:36pm
is there any way you could weld a smaller bolt or nut  to the one that broke off and remove it that way ive heard that that way works good sometimes good luck
NICKMI
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 12:43am
I have the best luck welding a nut or washer to them and turn them out. sometinmes i go through a few nut s or washers but it worth it when they come out. Matt
joegrgraham View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joegrgraham Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 4:11am
Weld a nut onto the end, not only do you have something to turn, the heat from the weld helps to free the stud.
If it seems like a good idea, do it. It's easier to apologise than to get permission.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 6:17am
weld as large of a nut as you can to the bolt, even welding the inside instead of the outside and walk away for an hour to let it cool. do not try to turn while it has any heat in it at all. the heat from welding and then cooling will shrink the bolt and it will come out. tighten the bolt ever so slightly first and then try to turn it out, working it back and forth. it may take a few welds and nuts but it will work.
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 6:40am
I saw them putting a car frame on a jig that they could turn it like a motor stand on one of those restore shows.
Jobs like yours would be nice to have a tracker stand to turn the tractor over.
Just dreaming
I have always drilled and fought with an EZ out and then ended up drill again and tapping the hole. I might try welding a nut on next time.
Good luke with it.
The universal answer to all questions is yes, how much do you want to spend?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 6:51am
weld a washer on first then weld the nut to that. easier than reaching down into nut for first weld. take a old candle or color crayon and melt wax into area also to loosen and lube broken part.
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 7:33am
Agreed.  By the time you try to weld to the inside of a nut you'll barely have any contact.  The washer trick works great!
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 8:01am
Stake it on the edge with a chisel,the tap it counterclockwise,I got one out that way.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 8:16am
Here is how I would do it.  First drill out the center of the bolt with a third the size of drill bit. Then take a wire welder weld the center back in. Then weld on a washer. As the bolt starts cooling, take a candle to the bolt. As it cools to the right temp, the wax will wick around the threads just like when you solder a pipe joint. Then take a pair of pliers and turn it out. The welding of the bolt hole makes the entire bold red hot, that breaks all of the rust loose by the swelling and shrinking, then the wax allows you to easily remove.  Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 8:16am
When I was still working, I bought a set of easy outs from the Snap-On guy. They have the right size left hand drill bits with each easy out. Many times I drilled the hole to have the broken bolt come out without using the easy out. If the bolt is bottomed in the threads, drilling can only help loosen things. If you don't want to mess with laying on your back drilling, weld a washer to the bolt, weld a nut to the washer and wrench it out. The closer the fit of the washer to the bolt, the better. I have never let the bolt cool completely before wrenching out and never had a problem backing the bolt out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 8:44am
Thanks for the input guys, I never thought of welding a washer on first to extend it below the hole, that sounds like the bset way. Not sure if the candling would work going up as the bolts are beneath the tractor? Dave63, I agree a rotisserie would be great... but probably a little overkill!
Edited by Bill_MN - 16 Jul 2011 at 8:45am
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 8:59am
I had one of them same WD bolts break about 4 years ago. Spun it out with a small chisel. Being upside down I believe no moisture ever got in the hole to cause corrosion.
I hope you got the same luck.
bluebanshee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bluebanshee Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 9:12am
I never seem to have any luck with the easy outs. Not much fun when the easy out breaks off in the bolt. Always come out using the welding/candle method or heating/candle only if its possible. Sometimes takes a few heat cycles.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 9:40am
I drill a hole in a strap iron and then weld it to the broken cap screw/bolt. That gives you a handle to hold it in place while welding. Like a washer, easier to weld, and serves as a handle/wrench to turn broken cap screw out.
Dusty
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 10:17am
Find the center of the broken bolt and center punch. It will most likely be slightly off center so take a 1/8" drill bit and walk the dint to a exact measured center. Drill the 1/8" hole on center straight and square. Enlarge the hole with a 1/4" drill bit. this will give you a pilot hole that will keep the tap drill for most sizes on center. Pick out the first thread or two with a sharp scribe. Sometimes the thread will coil out with pliers but not often. Start the tap but only turn in a 1/4 turn to chip out the old threads and back the tap up.  This will go much faster than you would ever imagine.  Probly faster than getting the welder around.
mdtractormechanic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 10:36am
As a heavy equipment mechanic for over 30 yrs, the above method has worked every time. As Joe says, the added advantage of heat expands the threaded end and crushes the rust. Make sure you let it cool before you attempt to remove the bolt. After it cools you may want to spray some penetrating oil on it too.
Joe's 1939 Model WC, 1940 Model RC, 1944 & 1950 Model C's, B-125 PU
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2011 at 7:39am
Start with the simple stuff first.
Try the chisel thing as BobH and Nathan suggested, You may be pleasantly surprised!
My Dad had a very small cold chisel he used almost exclusively for that.
' course he also had the patience of Job!  LOL
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2011 at 9:24am
This is one of the situations that a little gasless wire-feed welder is REALLY handy for... but any welder will do.
...Oh... really handy, because every time I get this call, the person who asks always lives just-out-of-tractor-driving-range from me.  Easier tossing it in the back of the truck, than the big welders.
Edited by DaveKamp - 17 Jul 2011 at 9:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2011 at 9:47am
If you are going to use the punch and chisel method, be very careful you don't swedge the bolt into the threads in the tractor. If it will come out this way, bigger is not better. After making your initial notch, groove or punch mark, use a small hammer and center punch to walk the broken piece in a circle with light taps.
 Back when I was doing die repair work, I spent more time grinding out what the set-up man swedged in than I did removing the broken bolts. " Can you get this out, I can't make it move"
Edited by CTuckerNWIL - 17 Jul 2011 at 9:50am
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2011 at 10:11am
If you start with a chisel and the bolt is broken off flush, you are taking a chance on damaging the threads in the case. The welding method is the quickest in the long run.
I should add this. The chisel method is simple in terms of tools and does work (sometimes) but can take even more time to get the job done if the bolt is rusted tight.
Edited by mdtractormechanic - 18 Jul 2011 at 10:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2011 at 7:22pm
on the subject of the welding, if a stud is ever broken off below the hole, there is a good stick weld rod i think it is called stud saver. you build up the stud by slowly weld, cool, weld, cool, small incriments, building up the stud until it is above the hole, then weld a big nut onto it and let it cool entirely. then tighten slightly then work back and forth until it comes out, the rod weld does not stick to the inside threads because the flux is made with silicone and actually will not adhere to the threads. you can get head bolts out several inches down inside a block. takes some time but works really well. never heard of the wax trick, i will have to try it.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2011 at 6:49am
Where do you find that welding rod? Hope I hope I never need it but would be nice just in case.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2011 at 10:54pm
bump
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2011 at 8:08pm
Here's a little something I found on welding up the broken bolt. Thought it would be interesting for everyone.
Ben
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 8:34am
Yes, the candle wax will work even upside down. The heat will draw it up and around the entire thread just like soldering a pipe joint upside down and you only have to touch the solder on one side of the copper pipe till you see the solder on the other side.
Wink
I am a Russian Bot
