D19 gas pulling tractor |
wrbewley
Joined: 02 Dec 2010 Location: New Haven, Ky Points: 43 |
Topic: D19 gas pulling tractorPosted: 09 May 2011 at 5:02pm |
I'm building a 262 to pull I am looking for ideas on a higher compression piston does any one have an idea of what could be used with the stock sleeves. I have diesel pistons but I think they are to tall.
Jim Hancock
Joined: 11 Sep 2009 Location: EL Reno, Ok. Points: 1112 |
Posted: 28 Jun 2011 at 12:10pm |
I understand so far that LP pistons will do.
wrbewley
Posted: 12 Jul 2011 at 4:25pm |
I have been unable to find LP pistons, any sugestions where I could find some.
CTuckerNWIL
Posted: 12 Jul 2011 at 7:57pm |
Use a standard piston with a longer rod, or use the diesel piston with a shorter rod. Make any compression ratio you want.
Posted: 12 Jul 2011 at 8:48pm |
You can machine .200" or .250" off of the tops of diesel pistons and use a thick diesel head gasket....been there dun that many years ago.....don't remember the exact depth of material but it's between .200 and .250.
MACK
Posted: 12 Jul 2011 at 10:01pm |
I would guess you are going NA ? If turbo the diesel pistons won't take it. MACK
wrbewley
Posted: 13 Jul 2011 at 6:55am |
I will be running na, I will be running it in the 4500lbs modified stock antique class, the tractor is actually a D17 diesel with a gas 262 out of a CII combine, I do have the pistons out of the diesel engine, so I will try shaving those pistons, I really didnt want to shave the block, how thick of a head gasket are you talking about, or do you just mean to use the diesel gasket.
Posted: 13 Jul 2011 at 6:58am |
Diesel gasket is much thicker than a gas gasket.
MACK
Posted: 13 Jul 2011 at 9:38pm |
Gas gasket is .035 diesels .065 MACK
ACD19farmboy
Posted: 13 Jul 2011 at 9:42pm |
haha u got the same idea as me man!!!! the hp of a D19 with the weight of a D17!!! this winter i will be building a D17 Diesel pulling tractor with a CII engine, but turned up and with a One-Ninety XT turbo!! POST PHOTOS MAN!!!!!!! Cordel
wrbewley
Posted: 14 Jul 2011 at 7:08am |
I've been pullin this tractor for a couple of years with the diesel, but with blowing head gaskets and lack of power was never competative. In the classes in ky we were never able to run a turbo. So i decided to build this engine hoping to hang with the Olivers with the bigger 6cyl that dominate the light classes. Funny thing is i was told i could never get this tractor less than 5000lbs, she ways in just under 4500lbs now with very little stripped off of it, but i plan to weigh in at 4000lbs when i am finished. If you need any parts for the 262D shot me a message i still have many parts off the old motor, including a good block. Will post pictures when tractor is done.
KGood
Joined: 17 Nov 2009 Location: Logansport,IN Points: 955 |
Posted: 14 Jul 2011 at 7:24am |
Wrbewley,there is a combination using the cockshutt version of the same motor that is sleeveless and had a big bore but short stroke. You just need to put the 262 crank in it cause it's longer stroked. I don't remember if it was 280 or 290 something cube. I'd like to see one pull done up that way.
CTuckerNWIL
Posted: 14 Jul 2011 at 2:38pm |
What kind of rule won't let you run a turbo on a tractor that came from the factory with a turbo? Nonsense!!
wrbewley
Posted: 14 Jul 2011 at 5:39pm |
The tractor is actually a d17 which had the same motor as the 19 but it was not turbo, so according to our rules no turbo allowed on the 17.
MACK
Posted: 14 Jul 2011 at 9:26pm |
Blown head gaskets is no problem. Have been running 70 Lb boost on a 262 and have never blown a head gasket. MACK
wrbewley
Posted: 14 Jul 2011 at 11:32pm |
I thank the six cracks in the head had a lot to do with it, I was blowing gaskets about every two hooks.
DonDittmar
Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2517 |
Posted: 15 Jul 2011 at 5:44am |
I would be interested in the block if it was closer |
