High-Low on a 7030
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Topic: High-Low on a 7030
    Posted: 05 Jun 2011 at 8:07pm
On my 7030 once you shift out of high side it willn't shift back up. Any help. T.I.A. Kenny L.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2011 at 8:38pm
Hi button on the floor ?? or Hi range on the Park lever??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2011 at 8:45pm
DrALLIS, the one on the floor. Kenny L.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2011 at 10:10pm
So, what does it do?? exactly, what does it do?....stop moving?? but works fine when oil is cold and then bothers when oil is hot??.......I'd guess leaking rubber seals on the high range piston or a dirty flyball or low gerotor pump flow or all of the above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2011 at 8:48pm
Dr.allis, it's after the oil get hot, it try to go but willn't move almost like it is slipping,and works great on low side. Thanks again Kenny L.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2011 at 6:19am
If the floor button stays down and it slips in high, I'd guess you have internal problems.......don't know the history (hrs) on it and it needs some gauges installed to verify pressures to be sure.
This page was generated in 0.297 seconds.
