Disc Size
Jeffh13 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeffh13 Quote  Post ReplyReply Direct Link To This Post Topic: Disc Size
    Posted: 31 May 2011 at 1:34pm
I just started a small 80 acrea hobby farm.  I just pickup a D17 and want to start using it.  Wondering good rule of thumb to use, on what size disc it could handle.  Soil is wetter and clay base.  I don't know if that helps...
Thanks..
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 2:04pm
I run a fairly heavy 8 foot finish disk on my 17.  I have sandy to heavy clay soil and in the clay its all she wants.  My 17 is an LP so a good running diesel would pull a little better.  Ballast and a properly set traction booster make a big difference as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeffh13 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 2:07pm
Running Gas...  Properly Set Traction Booster?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 2:13pm
The Traction Booster (TB) raises the plow slightly when it hits a hard pull versus lugging down or spinning.  Depending on what series 17 you have the TB is either on the steering column or on the hydraulic controls mounted on the right fender.  If you do not have an operators manual get one it will help you set the TB.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeffh13 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 2:15pm
Thanks...  I asked for one online..
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 2:22pm
Welcome to the forum by the way.  There is a wealth of knowledge here and some especially good people.
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 3:14pm
Welcome. As for your question. Depends a little if you are wanting a finish or cutting disk. I have a 9 ft. three point finish disk on mine and and really don't know it is back there. Wish I had a 11 or 12 ft. pull type.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeffh13 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 3:19pm
Well I'm looking right now and trying to find one.  I trying to narrow down the possiblities.  I think traction will be my biggest thing.  I never got suck except on ice with it.  But I don't really want to under size it and I don't want to beat it up either...  Looking at pull types....
Thanks
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 3:29pm
Im not sure if mine is 11 or 12 ft but its a Keewanee disk.  My WD 45 pulls it in 3rd with spike harrows behind it.  A D17 ought to take it no problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeffh13 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 3:47pm
I guess the on;y thing I can see that might be a problem is I have only one valve..
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 4:07pm
1 valve is plenty the disk do not have to be powered down ,
so you can operate them with a single acting cylinder
again it will depend on type of disk, a heavy off set bog disk at 6' wide will give it a work out,  but it will handle a 10' finish disk like my old kba john deere disk with out issue,
it depends on what you want the disk to do, cut deep into sod and bury trash or work freshly plowed ground and cut stalks
Edited by ky wonder - 31 May 2011 at 4:13pm
i like old tractors of all colors
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeffh13 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 4:40pm
So I guess I want go accross sod to cut it up a little so it drys up faster, so that I can plow it.  Disk up plowed ground and corn stalks.
So something like should be a problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 5:18pm
Jeff - that will work...but if  you want a disc that has good parts availability at a reasonable price get an IH 37 or 370 disc (just make sure if it's a 37 it's not one with old spool bearings).  I have a 10'9" IH 37 pull type that I love.  My 180 pulls it like it's not back there but in plowed ground it's a bit much for my D17's if you put it down all the way.  I wouldn't go over 10 feet.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeffh13 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 5:24pm
Thanks for the info....
I'll keep looking
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 5:34pm
I would agree with sky high. for a good disk I would go with IH. sorry no offense to those who might favor others but I haven't seen a disk cut better then a IH. But they think highly of them any more. used to be able to buy one for three or four hundred but now over a thousand.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 5:57pm
Jeff I have a 13.6 foot Kewanee disk I pull behind my deisel.  It is the old rigid frame model. I put all new blades on it several years age, I can pull it in high side of 3rd gear but I dont.  No mater how slow or how fast you go it ridges.  I would stay away from one of these.  Sold a 12' AC disk and wish I hadnt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 6:45pm
Is your disk pulling level? I would guess it's deep in the back. I've not heard of a Kewannee disc ridging if it was set up properly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 6:52pm
Traction Booster is a draft control activated by the amount of "pull" on the snap couple bell for shifting implement weight to the rear wheels for better traction. With a wheel disc you can get the hydraulics to "snitch" the disc up when pulling hard but it won't add much to your rear wheels for traction. An Allis SC disc will work better in tough conditions with the TB system but any good wheel disc will probably do you fine.
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 9:08pm
I pull a 13" allis disc with my D17 IV in third gear.  Handles it well.
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 10:24pm
Ten bucks says that your disc is not beamed in !!! Do you have an owners manual ? You need one !!! E-BAY
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 3:32am
there is always a certain speed for each disk to work it's best, to fast it will ridge, try different speeds for best results....my 13 ft kewanee does a great job at about 4 mph, any faster and it ridges. my allis center fold will ridge at 7 mph, 5-6 mph it does great! dad's old JD 12 ft did a good job at 3 mph. my Ih wing disk does great at 5 mph. and depending on how each disk is set, you want it to cut and move dirt at the same time! to many people want the speed, i prefer a good job done when disking, especially with the fuel costs nowadays.
Teddy (punchie) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 5:04pm
Here in the hills I have 10' is all I need.  You can still go down the road with them. I pulling them with a wd, in 3rd.  Not up a very good hill, just too much load.  This is a 9" inches between disks and 20" disks.
The d-19 pulled them any where. I would think a D17 should be a good match. What ever disk you use you have to set the cut.  Some work better at different angles.  Run them off set to the pass before.  You can move dirt with a good disk.
By far the best disk I have ever used is an very old drag  JD, not sure of model number, never found a manual for it, never seen an other one.  Weight is only about 600 lbs. 8' ; 7 inch between disks and no weight needed to make her work. Just set the cut and go. Make dirt move any way you want.  Easy to pull unless you are in loose dirt an set the cut too heavy. I have rebuild that old disk blades about 3 or 4 times.  I use twine in place of old wooden bearings.  Now mostly use it for finish disking the garden.  Use the trans. of going down the road.
Ac D-19, a Number of WD's, One WD45, Two 444 balers, Ac plows and etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeffh13 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 5:11pm
Thanks to all...
You have given me a good starting point.  Also gave me many things to think about that I hadn't thought about.
Thanks again...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 5:33pm
I rebuilt a 520 Massey last summer, cut it down to just under 11' by removing the wing gangs.  For the money I paid and the machine it is I came out pretty well.  The 180 will hog it full depth with the disc set to cut hard in 3rd/lo side if I want to but I generally keep it in 2nd/hi side.  It has only 18" discs but I put notched blades to the front.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 9:13pm
 SHAMELESS, You are very correct !!! Speed does matter !!!
nsula_country View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 10:16pm
Here is my Massey Ferguson 52 Disc Harrow that I recently rebuilt. I changed all gang bearings, moved the front blades to the rear, installed new blades in the front, new cylinder, new hoses, sandblasted and shot new primer and paint all over.
This is a 10" disc. My Farmall 504 diesel can pull it all day. The 504 diesel is 42 hp drawbar, 48 hp pto new. My 504 was built in 1962 and has never had an engine or injector pump job preformed. I plan to use my recently acquired Allis Chalmers 180 on it to see what its made of!
Here are some pictures of my restoration.
Enjoy!
CT
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 11:00pm
did i see ya disking sum firewood? nice disk!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeffh13 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 6:43am
Sweet...  Still Looking...
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 2:26pm
Breaking and leveling new ground I had cleared a few years ago. Why cut firewood when you can dig it up!
CT
This page was generated in 0.065 seconds.
