What Planter is this?
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Topic: What Planter is this?
    Posted: 27 May 2011 at 11:23pm
Anybody know what kinda planter I got here? Its the one my Grandpa used to farm with. He always used it behind the WD45. Looks to be in decent shape, one hopper has been taken off for some reason, everything still turns freely and works. There are extra seed plates hanging in the barn. I pulled everything out of the barn to do spring cleaning.
Also have the 3 bottom snap coupler plow.  Both of these implements have been with this tractor a long time. It is all still kept in the 3 section dirt floor tobacco barn. I have the planter and plow setting up on boards and plastic after cleaning and re organizing everything. Plus alot of WD45 parts hanging all over the walls.
Edited by 79fordblake - 27 May 2011 at 11:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2011 at 11:32pm
I'm pretty sure it's called the "All Crop" planter. I have one just like it. It's the same one that had seed plates that fit in a John Deere planter.
Edited by Brian Jasper co. Ia - 27 May 2011 at 11:34pm
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2011 at 11:39pm
   The plow is a model 63.
http://www.rumelyallis.com
Wil M (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wil M (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 6:05am
It is known as a Rear Mounted Drill Planter.
Wil
"Yet there are soulless men whose hand and brain tear down what time will never give again." Anderson M Scruggs
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 3:24pm
That is the planter we used when we were selling.  Yes, it used plates and you could vary the distance between drops by using various chain gearing.  Worked fine for us till the no till came out.
You may well find some almost anywhere cause it was the standard AC planter in the 50's.
Good Luck!
Bill long
This page was generated in 0.110 seconds.
