AC pwered Genset
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Topic: AC pwered Genset
    Posted: 16 May 2011 at 3:10pm
Our company is offering this unit up for sale.  Any ideas what the engine is (or what it will fit into)
'40 WC puller,'50 WD puller,'50 M puller '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 3:22pm
larry     There  should be a tag  on  engine  , it will tell the story . We need  model  number to figure out what it  is.      Tony
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 3:43pm
By the way the oil cooler is it sure looks like a 426....but should have the tag to verify
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 4:10pm
i will see what I can get.  I only have pictures of it and have not seen in person
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 7:04pm
Its a 426 engine same time frame as the d-21 210 220
amac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amac Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 8:44pm
How much are they asking for it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 10:05pm
I'd say 210/220 because of the TO-4 "B" turbo and I think a deep oil pan with crank driven pump?? ...might be a place for tractor hydraulic pump to mount??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 3:25pm
I just got some info on the engine.  They say the tag says Model # 3500.  Order number is 1-7451-63281
They said it needs a rebuild because of some bad blow by and water in the oilpan
No one has bid on it yet.  It is a 600.00 starting bid.  What do you guys think??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 6:07pm
On one that vintage they only had two Orings on the sleeves....that'd be my guess.....as long as they didn't spin a crank brg from not catching it soon enough, it should be an inexpensve fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 8:31pm
is that a 210/220 or 21 then
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 9:51pm
All three only had two sleeve Orings.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 12:36am
My opinion is that gensets of this size and quality are bargains beyond all belief!  People frequently go out and buy little air-cooled rattletraps, and pay way too much to have them hooked to silly little emergency panels, when they could've had much more substantial machines suitable for whole-house transfer... for much less money.  Yeah, larger machine uses more fuel, but if you live in a location where cold winters occur, you can win BACK most of that fuel-consumption penalty by tapping the cooling system, and diverting from radiator to a heat-exchanger, and pipe hot water into the house for heating, thus getting bettern' twice the energy recovery from each gallon of fuel burned.  That's exactly what I do with my trio of generators.
Windings in that generator head are made of the best copper on earth, the genhead can likely be wired for any power output you'd like... single or three phase, 208/125Y, 120/240, 480/277Y, 230 Delta... whatever suits you best... and it has serious protection circuitry and durable electronics, not something that'll blow up and die when an electrical storm strikes close-to-home.
Even with a marginal engine, $600 is a hard pricetag to beat...
