CA Wide Front Repair
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Topic: CA Wide Front Repair
    Posted: 14 May 2011 at 11:20pm
I've never seen a CA wide front that wasn't wore plum out. Most so bad they are actually riding on the cast bolster. Here is a fix in progress with grease hole. Pin size was made larger to 1".
FHOliver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FHOliver Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 12:40am
that looks good , you are right though most of em are in tough shape
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 8:42am
I've got 3 wide front ends here at the house and all were worn just like the one pictured. And when you drive a wide front with that much wear they drive terrible. Anyone have that s not worn?
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 2:53pm
Hey Bill, nice job! I like the grease fitting idea. I'm also in the process of rebuilding one of my wide fronts. Welded and ground the pin, double passed all the old welds, and added a couple support brackets to the wishbone. Post more pics as you get further along in your rebuild. Ron
CA Tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 2:58pm
Here are some pics of mine.
CA Tractor
