WD45 with duals
BCPuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BCPuller Quote  Post ReplyReply Direct Link To This Post Topic: WD45 with duals
    Posted: 07 May 2011 at 12:55pm
just test driving the 45 with duals after having the head redone[TUBE]5UelEBCUj0w[/TUBE]
Richard S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richard S Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 1:02pm
Why are some of the rear tires on backwards?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BCPuller Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 1:28pm
We pull on cement and if we want to pull on dirt we just turn them around!
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 4:18pm
Any "secrets" on the head work you'd be willing to share? I could tell that wasn't stock RPM in the video.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 4:42pm
Thats how mine sounds at full rev in 2nd gear, only thing done to the motor was the D17 kit
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote BCPuller Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 12:10pm
No secrets on head we just put in new valves and seats! that was a little over half throttle!
Post Options Post Options   Thanks (0) Thanks(0)   Quote BCPuller Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 12:11pm
RWR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RWR Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 7:42pm
Does it pull good against john deere g's
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 7:51pm
Since the 45 had the same stroke and bore as the 17, what is a 17 kit? Did they up the compression ration with different pistons.
Gregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 9:39pm
One time our local tire man put triples on the rear of a JD B.  It sure looked cool in a parade.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BCPuller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2011 at 6:30pm
on the post about John Deere G..   Yes we did today, slipped in there.
Thanks for letting me pull your wd45 today TOO!
RWR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RWR Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2011 at 8:36pm
it felt good to put the orange on top today
This page was generated in 0.184 seconds.
