front donut weights
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Topic: front donut weights
    Posted: 06 May 2011 at 2:47pm
I cleaned and painted my donut weights for the front wheels, put them on my D-14. I took it out on a test run and the wheels were out of balance so bad, that I couldn't drive it. Has anyone else encountered this? Is there a correction for this?  Dave.
Chad (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 3:33pm
David,
I have a set on my narrow front WD and traveling in road gear is a handful because the weights put the wheels out-of-balance.  At lower speeds, I don't see/feel the "wobble" like road gear.
Chad
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 4:09pm
David I have a set on my WD I got from JR in Oaks ND and they run fine in road gear.  Mark
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 4:13pm
Maybe you could try to center them better if there is any play.
Mark J. N.Y. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark J. N.Y. Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 8:01pm
The ones on my D-10 and D-14 shake the H&#* out of the steering wheel on both tractors..................
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 9:23pm
The way I mount mine they don't shake at all......
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 9:32pm
Eldon: I knew you were a highly educated individual, now I know for sure.  I was wondering if maybe the inside half weights might have been engineered to take up for that. Does anyone have both sets, and does that help? Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 9:35pm
I have a tractor drive tomorrow, so I took them off, I was afraid it might hurt my tractor. I will only have the two younger Grandsons in the carryall, last year when all three rode it made the front a little squirmy. Now after a year of full feed, I know I will be in trouble.  dave.
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 10:22pm
I have donuts on both my gas and diesel WD45s, I've put them on and taken them off for different weight classes when pullin and put them back on with no reguard to how they were mounted, and they have always worked fine.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 10:23pm
Dave ol' buddy...I'll just take those front donut weights off your hands and then you won't have to worry about that any more! LMAO! But...seriously...............  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 11:02pm
Dave - I've pumped -20 windshield washer fluid in the front tires of my D17 Series IV and it runs great in road gear out on the pavement, no balance issues at all.  About 6 gallons each tire for 6.00x16 - about 48 lbs each tire.  Mike
P.S. It's closer drive to my farm than Rick's place if you are looking to unload those donut weights...would go good on my Gleaner steer tires.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 6:56am
Ah...but,Mikey...I'll be going to Bates City come Monday morning (very early) and could just make a quick detour! LMAO!  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 1:54pm
So maybe the ballast would make up the difference?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 4:34pm
Great thanks!  Just drop them off at my farm on your way back east!  Thanks Buddy!!!
LMAO!  Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
