616-620 starters
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: 616-620 starters
    Posted: 30 Apr 2011 at 9:25pm
Do the 616-620 AC tractors with Onan engines use the same starters. I have one I think has died. Looks like a fun thing to replace also. Probably as easy to pull the engine. Any tips in swapping it out? Thanks Tracy Martin
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2011 at 9:27pm
you do have to pull the engine to get at starter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2011 at 9:30pm
Tracy, starters are basically the same...may be a different mounting bracket.  As was said...you will have to pull the motor to change.  The main thing we have found, dry fire the starter before re installing the engine.  There is enough play in the mounting holes to cause noises in starting that indicates things are not good.  Hard to describe but you will know it when you hear it binding up on start up.  Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
