Oil Change Questions WD45 |
nickendres
Topic: Oil Change Questions WD45Posted: 22 Apr 2011 at 4:10pm |
So this might be pretty basic, but I found conflicting info while searching on here... Most old posts said to use 10W30 for the engine oil in a WD45 and I found at least one that said to use a non-detergent oil. Any opinions on this? I'm not used to working on engines this old and I want to make sure I don't screw it up!
Thanks!
nickendres
Posted: 22 Apr 2011 at 4:11pm |
k
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24880 |
Posted: 22 Apr 2011 at 4:16pm |
I've used 5W30 or 10W30 ( whatever's on sale) in my D-14 for 8 years...sems fine to me. Gets Spring and Fall oil changes, with new filters.
RSponenberg
Posted: 22 Apr 2011 at 4:17pm |
I have used 10w30 in the past now I use 15w40 it gives me a little better oil pressure in the summer.
John In.
Joined: 20 Sep 2009 Location: New haven In. Points: 69 |
Posted: 22 Apr 2011 at 5:01pm |
if your engine has not been overhauled I'd stick with the non-detergent 30 wt. oil. |
CTuckerNWIL
Posted: 22 Apr 2011 at 5:10pm |
I use 10W30 in my WD45 because I use it in the winter and the summer. I don't know what had been run in it before I got it but I was told it had been OH not too long before so I wasn't concerned about any old crud being dissolved by the detergent and messing something up. If you only plan on summer use, use a straight 30 weight non detergent if you can find it.
Gerald J.
Posted: 22 Apr 2011 at 5:14pm |
I think using 30 weight non detergent oil is abuse of the engine. Additives in detergent oil also prevent corrosion of silver and copper bearing inserts when poinsture is present and tend to not have excess sulfur to also corrode those bearings (cam, rod, and main). If an engine has so much crud that detergent oil will make it move around that engine has been on non detergent oil way too long.
Single weight oil lubricates less well at starting and then gets thin faster to lubricate less well when hot than a multigrade. And in cold weather can be as stiff as axle grease. When cars used 30 weight non detergent, even with regular oil changes they often ran only 35,000 between overhauls. With multiweight and somewhat improved engine designs they started running more than 100,000 miles between overhauls. Gerald J. |
nickendres
Posted: 22 Apr 2011 at 6:01pm |
Thanks for the info- It's my Dad's tractor, so who know's the last time the oil was changed! I think I'm leaning toward 10w30, but I can see why you might go with non-detergent if that's all that's ever been used. I'm assuming that it probably has 10w30 in it now, but that's just a guess.
Gerald J.
Posted: 22 Apr 2011 at 6:17pm |
After its drained. Reach up through the drain hole and explore the bottom of the pan, with wire or finger to see the amount of deposits. If there are some, change the 10w30 more often to rinse it out.
Gerald J. |
j.w.freck
Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
Posted: 22 Apr 2011 at 9:41pm |
i use valvoline 40 wt.racing oil in my gas tractors on the ranch,good oil and the oil pressure is always good .and the oil consumption is very mininal...
427435
Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Posted: 22 Apr 2011 at 9:56pm |
If it doesn't get used in the winter, a modern 15w-40 dino oil would be better than 10w-30. Change every 100 hours or yearly, whichever comes first.
If used in the winter, I would recommend Mobil 1 5w-40 turbo diesel oil year around and changing once per year or every 200 hours, which ever comes first. It has more zinc for flat tappet cams and bearing wear than the newer 10w-30 oils and is also rated for SL and SM gas engine use. If, as suggested above, you find some gunk around the drain hole change it more often for a while. |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
427435
That might work in Texas, but not in Wisconsin in the fall or winter. |
Mark
indiana2door
Posted: 24 Apr 2011 at 7:36am |
Only a fool would use non-detergent oil in anything.
OrangePowerFranzen
Posted: 25 Apr 2011 at 12:21pm |
use rotella engine oil, seems to be the best for all the stuff we got
Denis in MI
Joined: 15 Sep 2009 Location: Norvell, MI Points: 832 |
Posted: 25 Apr 2011 at 12:31pm |
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
KY
Posted: 25 Apr 2011 at 2:45pm |
Any diesel grade oil is better than gas to take the extra abuse.
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6108 |
Posted: 26 Apr 2011 at 10:13pm |
Unless the fool was aware that there's some cork, leather, felt, burlap, or other old-time gasket, wick, or breather materials in there that didn't tolerate detergents well...
Not a common issue nowdays, especially if the engine's been rebuilt, but if someone was giving a very, very, very expensive 100-point totally NOS/OEM rebuild for a Duesenberg SJ, and the original spec happened to be a non-detergent... what would you think they'd do? Edited by DaveKamp - 26 Apr 2011 at 10:18pm |
Posted: 27 Apr 2011 at 6:24am |
Dave... Probably some ultra over priced synthetic, 'cause 'they' say 'it's the greatest oil that's ever come along' and 'you've got a lot invested in the car , why take chances with inferior products ?'. I agree you should use what the manufacturer recommends, but after 40,50,60 + years of undocumented oil changes WHO knows what went through the engine??? I've seen some ,filter their old engine oil to reclaim it to save a few coins,and honestly after 10 years of doing it, never saw the engine get 'upset' over it.Seems more important to always change filters twice a year, or every xxx hours of use.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12043 |
Posted: 27 Apr 2011 at 7:19am |
I don't know. In my own opinion, its silly to me to use "old style" non detergent oil, when todays oil is far superior. To me, that's like buying a new pair of work boots and using the old laces. I use 10w40 in all my equipment, Tractors, Hot rods, and shop van with absolutely no problems at all. Crankcases and valve covers are nice n' clean inside, and even with 3000 miles between the oil changes, the everyday cars dipsticks still show an Amber hue to em'. That tells me, things are nice n' clean inside. JoAnna's CTS Caddy is the only vehicle in the fleet that I use Mobil 1 oil in, and that's only because that's what came in it from day one, and I keep it that way. Because her job is only 15 minutes away from the house, the oil changes are fewer in the Caddy so its easier on the wallet when it comes to an oil change. In the summer months, she rather drive the 29' P/U to work instead anyway. Sheesh, I gotta' pry her outta' that thing sometimes so I can have a turn drivin' it once in a while! LOL!
DaveKamp
Posted: 27 Apr 2011 at 3:21pm |
Realize that when old engines were built, there was no filtration system, and the oiling systems may not have been in the same realm of today. The Model A Ford, for example- had splash-oiled lower end. Air filtration and oil filtration didn't exist. Not uncommon for early engines, but other manufacturers rapidly saw benefit of partial, and later, full pressure lubrication. Then, manufacturers realized the benefit of filtration... added air filters and bypass (partial flow) filtration, later went to full oil filtration.
Early engines managed heavy crud, by using the bottom of the oilpan as a 'catch', knowing that heavy sludge would fall to the bottom, and simply not be light enough to get picked up and fed back into the engine. Obviously, loosening up crud and sending it through the bearings a few times isn't a good idea, particularly when you use poured babbit (like a Model A Ford), and start loosening up old gunk and splashing it on the lower end of the piston walls... or on a partial flow, pumping it up to the valve cover, and having it plug up an elbow, or the filter... etc. So as odd as it may seem, the ramifications may have merit. Center of a crank... the pilot bushing... not unusual on some old motors to have a passageway that brings engine oil through a drilling in the crank, into the pilot bushing cavity. Typically, flow through here was minimized by something SHOVED in there... and covered by a piece of wick (felt, etc). Sometimes that plug... was porous wood (balsa, cork, etc)... when that plug fell apart, you'd end up sending oil out the bushing, and into the clutch. Ever been there? I have. (sigh). Non-detergent oils burn better than detergent types... pretty important when you're working on an engine that was not manufactured to tolerances as tight as modern engines. Run a non-det in an old flathead, you'll see less frequency of valve guides sticking to stems. Flathead guys, as a result, swear by putting additives in (Marvel Mystery Oil is one of 'em) to help rinse the gum out. Understandable, and my experience seems to follow that. Back when old engines were new, a 3000 mile oil-change would've been considered insane... think the MAF was what... 20hrs or 200 miles? Probably wrong, but the magnitude ain't too far from truth. There's nothing wrong with revisiting things like this, but always realize that there's ramifications to everything- make sure you either look at every possiblity, or be prepared to accept consequence. If you dig into the specific forums, you'll probably find guys that've figured out the sensitive issues, and made slight modifications to 'go modern', which is one of the biggest benefits of forums like this. |
DaveKamp
Posted: 27 Apr 2011 at 3:28pm |
In dry environments, it wouldn't be as prevalent, but the short-trips are frequently worse, because the engine never gets up to temperature to clear out moisture... wind up with a milkshake plugging up the PVC valve, and the dipstick gets white milky goo. My '82 Ford pickup had a 300 six that suffered that constantly, on account that my morning commute was only 10 minutes each way. When I changed to driving 35 minutes, the problem (and constant PVC replacements) went away. |
Posted: 27 Apr 2011 at 3:47pm |
Reminds me of the so-called 'experts' these days that say you do NOT have to let a car warm up in the dead of Winter.Oh, you only need a minute or so, that's fine...'they' say.
I'm greatful for the auto car starter I bought a decade ago. That 10 or 15 minutes of idling allows the oil to warm up, the rad too and maybe most importantly allows the automatic tranny fluid to nicely flow....
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 27 Apr 2011 at 4:41pm |
From the real old school with the possibiity of offending some very good friends and very excellent opinions and to perhaps expain the reasons for the use of non detergent oil in tractors and tractor hydrallic systems.
When we sold Allis Chalmers 1936 - 1962 we used and swore by non-detergent oil. First in the hydrallics since at that time the better trans axle oil was not available and the detergent oil foamed under high pressure - 3000 psi. Second in the engines. Especially engines that had not been overhauled. We found that if the higher detergent oils when used in older un-rebuilt engines it could cause oil leakage and burnng. Sometimes, the first thing we did when we had old tractors fouling plugs cause they were burning oil was to change the oil and use non detergent oil. Straightened them up for another few years before overhaul. Remember this was the 30's 40's and 50's. Money was not always available for an overhaul. So you got the most you could out of it...
However, now with the more exotic oils available I have heard excellent results from the newer oils even in older engines and hydrallic systems.
Thereby, I stand corrected that quite possibly it is better to use the detergent oils in the engines and the trans axle oil in the hydrallics.
Good Luck!
Bill Long
Gerald J.
Posted: 27 Apr 2011 at 5:24pm |
The "experts" who say a minute is long enough warm up are mostly worried about air pollution and fuel consumption, not engine wear. A cold and idling engine is a more serious polluter than a working engine that's warming up fast. And likely the catalytic converter is doing nothing because its cold, the engine is running rich and so puts out more unburned fuel and carbon monoxide while the fuel efficiency is exactly zero. No miles per gallon.
Gerald J. |
427435
Posted: 27 Apr 2011 at 5:43pm |
Boy, this is getting interesting. I have to comment on the "warming up" of engines. In the good old days, that was often necessary due to stumbling that would occur with a cold engine that was carbureted. The dino oils back then also had cold flow issues.
With today's fuel injected engines and a good synthetic oil, my cars get started and driven-----although not hard for the first few miles. I've got a 1994 Mercury Topaz that was my drive to work car. I never took the time to warm it up (running late or just want to get home) and it now has 232,000 miles on it. No engine issues and still doesn't use any oil. It did always get Mobil 1 oil every 6,000 to 9,000 miles, however. As far as emissions, we all breath the air. |
Mark
DaveKamp
Posted: 27 Apr 2011 at 9:30pm |
Well, if you have a vane-type hydraulic pump in the car's power-steering system, and it's -25F, you might get quite a pucker-factor when you go to back up and turn, and find out that... you've got no power-assist... when fluids are that cold, vane-style pumps don't extend quite when they should, and if it doesn't, no hydraulic power.
My Clark IT60 is getting a completely new hydrostatic full-time 4wd system, with closed-center hydraulic steering, all disengageable via engine-clutch, so that I can START it in -20F (with no parasitic drag), then, once warm enough to take a slight load, let out the clutch and get the hydraulic system pumping slow, warm it up to the point where it'll actually work. The old system used a big vane-type pump, and if the fluid was really cold, you could start and rev that thing all you wanted, you'd have no steering, no mast controls, and if you revved it really hard and beat on it, the vanes would extend for a moment, and rip the coupler right in two. But I like Mobil 1 synthetic... my zero-turn's 27hp Kohler V loves it too... |
Bill_MN
Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Posted: 28 Apr 2011 at 9:53am |
Not to hijack this post, but I take my tractor out for a couple months in the summer to drive around and pull/plow at our local show. I'm thinking of using 5W40 synthetic rotella and changing it every 2-3 years along with the filter, since synthetic doesn't break down as much over time. As little as I use it I don't think the oil needs to be changed every year. Any opinions?
Edited by Bill_MN - 28 Apr 2011 at 9:54am |
BobHnwO
Joined: 16 Sep 2009 Location: Jenera Ohio Points: 693 |
Posted: 28 Apr 2011 at 10:03am |
Bill,that's what the Shell Guy said to use in my 7060,runs cooler.
CTuckerNWIL
Posted: 28 Apr 2011 at 11:23am |
My 45 doesn't get used much either, push snow in the winter and maybe mow some brush a couple times in the summer. That's why I use regular oil and change it yearly. I'm afraid with less use it might collect condensation in the oil.
Dave in il
Joined: 22 Sep 2009 Location: Manville Il Points: 1748 |
Posted: 28 Apr 2011 at 12:42pm |
My 45 has been overhauled twice since we've owned (it was a year old when Dad bought it) and it's been on detergent diesel oil since Dad bought the D17D around 1960. One drum of oil for all the tractors. Now I use 15w 40 diesel in WC's through 8070 with no problems.
