D17 3pt hitch?
cmpman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmpman Quote  Post ReplyReply Direct Link To This Post Topic: D17 3pt hitch?
    Posted: 23 Apr 2011 at 8:11am
Hello again I was wondering if I can put a 3pt hitch on my d17 industrial if It never had one. There is just a plate on rear end .
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2011 at 8:54am
Here's the 3-point I built for my D-17.  I'm betting that by your description, yours has no rear lift... so you'd obviously need to do some things differently.
My suggestion, if you do, is NOT to use the stock lift system, particularly if your industrial already has a low-pressure/high volume hydraulic system... instead, build your own beefy lower end, and fit on double-acting cylinders to act on the lower lift arms.  This will solve you hydraulic headaches, as well as give you the capacity to use downpressure for scraper blades, etc.
Also, with that kind of brute force capacity, I wouldn't build the lower bracket like mine-  I used the four big bolts under the transaxle casting to bear draft and load... instead, for more beef, I'd distribute the load up around the axle tubes and at the snap-coupler draft point.
Edited by DaveKamp - 23 Apr 2011 at 8:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmpman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2011 at 3:53pm
I don't have a rear lift just a plate is it hard to find one, and how do I control it I dont have any controls for rear pto
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2011 at 10:41pm
An industrial is a flat back and doesn't have a rear lift on it.
It may not even have the internal hydraulic pump or the controls.
Industrial unit usually had a front mounted pump for a loader etc. Bob
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2011 at 10:59pm
pictures would help
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 12:40am
CMP-  if you were me, what you'd do is drain the rearend, take the plate off, and use it to make a template for a new plate, but larger, and incorporate mounts for a pair of double-acting implement cylinders, two lower lift arms, and one upper lift arm for a Category 1 or Category 2 3-point.
For controls, you'd use whatever 'live' hydraulic system was available, and pipe it to a multi-section valve to operate both your 3-point, and any other tools... i.e. loader, belly blade, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmpman Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 6:28am
Thanks for the info I will try to get some pics of the old girl on the web site later. Happy Easter
This page was generated in 0.127 seconds.
