Allis chalmers 653 dozer |
cid25136
Joined: 17 Apr 2011 Location: pennsylvania Points: 5 |
Topic: Allis chalmers 653 dozerPosted: 17 Apr 2011 at 11:54pm |
just purchased this dozer from a local dealer with no manual. i was hoping if someone can tell me where can i purchase part for it,, also hoping if someone might have the oil filter number for this dozer. i cant locate the serial or the year it was made...sorry
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42285 |
Posted: 18 Apr 2011 at 1:40am |
same as a 655 or HD4 , AC 2200 engine , single fuel filter acts as primary and secondary.
Srl # should be stamped on upper frame in front by grill guard, top flange of that member.
only difference is it should be pedal steer instead of lever steer
cid25136
Posted: 18 Apr 2011 at 5:23pm |
wonderful, was also looking for a service manual for the 653 dozer, the cheapest i found was sixty dollar....anything cheaper out there?
Kurzy
Joined: 02 Nov 2009 Location: WSS, Montana Points: 808 |
Posted: 18 Apr 2011 at 6:29pm |
Howdy,
I bought all the manuals for the AC 653 long ago. I thought by now I would have a 653! Still going to hang onto them. May get one yet!
Kurzy
Coke-in-MN
Posted: 18 Apr 2011 at 7:40pm |
Oh for hind site , when i sold my machine I threw the parts, service and shop manuals all in with it.. Same as with last HD5 had exter manual so I loaned it to guy , last I see of that one also.
cid25136
Posted: 18 Apr 2011 at 9:50pm |
cid25136
Posted: 18 Apr 2011 at 9:59pm |
thanks for your quick response to my questions, this next question pertains to owners of the ac 653. this 653 has no history and who knows how many hours was put into it. i was hoping for some advise on changing certain items on dozer before it becomes a problem in the future. i already planning to change the oil and the 2 (12) volt batteries.. any hints on what has to be replaced before running her for long hours?
Coke-in-MN
Posted: 18 Apr 2011 at 10:08pm |
Check your finals , reduction gears , check rear sprocket for play , the bearings on the final bullgear is supported by two roller bearings , one inner (small) and outer by sprocket.
don't shift under full throttle from fwd to reverse and back, decillerator is needed on machines .. ATF in the converter and in clutch pack, small filter in that system.
Keep the air filters clean , tap out dust regulary. be careful not to dammage element.
It will run fine on a single 12 V battery of 800 to 1000 CCA. It uses a small frame Delco starter with 3 bushings, (center bushing behind starter drive)
cid25136
Posted: 18 Apr 2011 at 10:28pm |
outstanding, just purchased the manual for 42 dollars, i print out the check list, just going to cross reference it with the manual and pray for the best..thanks!
Coke-in-MN
Posted: 18 Apr 2011 at 10:42pm |
Watch your track adjustment , you need some slack in track , not overtight. Keep track clean by shoveling it out each day and making sure if running in soft sticky ground there is places for dirt to clear from track.
They are good small machines but do not overdue the machine , they were made for industrial and light commercial work and not heavy construction type . Don't bang or jerk things then with torque cnverter it will cushon some of load. Grat for finish grading and light dozing but they are not D4 or FD5 machines. MY HD5 would outpull , lift, drag, push or most other things than my HD4 , but the 4 was faster on small jobs and lighter in weight.
also remember to take it slow in reverse as track wear is like 5-X in reverse over fwd.
farm72
Posted: 18 Jun 2015 at 11:34pm |
I am looking for information on AC 653, could you share?
Scott 262-424 6474
ivan
Joined: 12 Sep 2009 Location: NE Michigan Points: 319 |
Posted: 19 Jun 2015 at 7:39am |
We sell parts for 653 989-379-2721
farm72
Posted: 20 Jun 2015 at 1:23am |
farm72
I will be in touch
scott
