190 hp
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Topic: 190 hp
    Posted: 12 Apr 2011 at 7:29am
can some one give me the hp test for the 190 301 gas the 190 301 diesel and the 190 301 turbo
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 9:58am
Just google the tractor model with Nebraska Test behind it.  You will find a link to the Nebraska Test of that model in the the top 2-3 links.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
Romaninmi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Romaninmi Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 10:07am
Gas 82, turbo diesel 93,  non turbo 75
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 10:11am
Here are some tests from the 190XT
Nebraska Tractor Test 887:
Test Date: April 10 - 16, 1965
Engine: diesel
PTO power (rated engine speed): 93.64 hp [69.8 kW]
PTO power (rated PTO speed): 89.71 hp [66.9 kW]
Drawbar power (max): 79.12 hp [59.0 kW]
Nebraska Tractor Test 927:
Test Date: November 9 - 17, 1965
Engine: LP gas
PTO power (rated engine speed): 85.25 hp [63.6 kW]
PTO power (rated PTO speed): 76.36 hp [56.9 kW]
Drawbar power (max): 71.95 hp [53.7 kW]
Nebraska Tractor Test 929:
Test Date: November 9 - 16, 1965
Engine: gasoline
PTO power (rated engine speed): 89.53 hp [66.8 kW]
PTO power (rated PTO speed): 82.30 hp [61.4 kW]
Drawbar power (max): 76.65 hp [57.2 kW]
