Well guys in between
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: Well guys in between
    Posted: 02 Apr 2011 at 5:32pm
flying way too much I have managed to finish the D19 front hydraulic pump and plumbing installation as per all of your help. It is sweet and smooth. I flew all night again last night, took a nap and now I am into my D15 II 'Diamond' [in the rough of course]. lol Last year we split Diamond and put in new main clutch, pilots, etc. Today I ripped into getting the head removed. She had a leaky head gasket and I could hear a valve hissing sound. The head now sits awaiting me to take to the Valve guy. I see both intake valves on nos. 2 and 3 have issues where they are not seating correctly. I will get a valve job and install with all new gasket set. Then hopefully I can rake and ted in comfort. Nothing against the 49 WD...but my disc can't take another summer sitting on the catapault seat. I like standing while driving for my back. Wish me luck!
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 5:40pm
Dana, Don`t use the AC head gasket. they don`t have fire rings in them. I used FelPro and they have fire rings.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 5:51pm
Bergie what in hecks a fire ring? lol I just knew this wasn't going to be cut and dried! I found 2 pushrods bent! Here are some blurry pics of the 2 intake valves that have scarring at one's 10 oclock and the others 2 oclock positions.
What causes pushrods to bend? Foreign objects being trapped in valve? Oh, and when I took out the bolts that hold the head down, the bigger ones were not tightened, I could unscrew with my fingers. However I retightened them to make sure the holes weren't stripped...and they are not , they just were loose hence the head gasket leaking. Do I need head planed?
brettIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brettIA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 6:19pm
bent push rods are caused by the load at the top of the push rod exceeding the rated load of the rod lol , i've seen ( just this week ) a stuck but not bad valve bend rods ! taped the valve down with a hammer and it stayed there , sprayed it with wd40 and turned it with vice grips and it became free . runs great now but as enough to bent the pushrod
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 10:07pm
Could it be that someone gave it too big a snort of either?
Allis Express participant
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 10:17pm
I'd bet on a stuck valve bending a push rod....seems it doesn't take much for a valve to stick in the head if it sets awhile....just my experience.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 7:04am
Dana, Fire rings are the metalic rings in the head gasket where the head seats against the sleeves.
"Burgie"
This page was generated in 0.111 seconds.
