Sherman splitter ID....
Unstylish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unstylish Quote  Post ReplyReply Direct Link To This Post Topic: Sherman splitter ID....
    Posted: 28 Mar 2011 at 9:27pm
I picked up a sherman splitter from a WC today. It is complete and in good shape, but I dont know if it is a step up or step down. Which position is direct drive? It only has 2 positions. Someone said that the step downs had 3 positions, direct, neutral and low..
Any help? I need a step down...
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 9:34pm
I would think you could turn the input shaft and compare it to the output and then shift it and do the same. One way has to be straight thru and the other is either slower or faster.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2011 at 1:04am
Forward is direct drive.
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2011 at 5:21am
I have some tooth counts, etc that I got from Barney several years ago.  Are the gears narrow or wide...about 3/4 or 1 1/2.  I'll get the numbers and get them posted.  remind me if I forget, kinda busy with spring sports and kids
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unstylish Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2011 at 6:27am
I'll measure them later tonight when I get home.  I think they are wide.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2011 at 6:59am
I had a step-up that was 25% over
Pipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pipe Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2011 at 7:07am
I have a step down stright threw and low range are the only two gears .
I also have one for a b or c now that has a stright ,low and a high range 25% each.
This page was generated in 0.060 seconds.
