Traction Booster Hitch
AC Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Man Quote  Post ReplyReply Direct Link To This Post Topic: Traction Booster Hitch
    Posted: 24 Mar 2011 at 7:06pm
would anybody have any information on the hitch that hooks in the snapcoupler and fastens to the lift arms and your disc hooks to it to let traction booster work.
Gary IN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary IN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 7:25pm
If you are looking to buy on I have one that I never use. Gary IN
plowboy8550 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plowboy8550 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 8:21pm
If its not spoken for how much do you want for it?
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 8:41pm
It sounds like you want a 3 point adapter.  Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 8:50pm
I have a wheel disc that only hooks to the drawbar. The traction booster will "snitch" the disc up in hard pulling but it doesn't add weight to the back wheels like a true snap couple disc does.
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 10:30pm
he is wanting just the hitch you will find info about in allis lit it is the hitch for the big capacity tools that allowed you to pull a 14 foot disc and other wheel mounted implements and still use the traction booster system, you take the drawbar off and hook this up to the snapcouplers both upper and lower and then hitch the disc or other tool up and away you go.  I have 2 of these but that is all I have seen except in pictures
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 10:45pm
AC Man, what kind of disc do you have? If it is an AC snap couple disc missing the hitch, you might end up buying a parts disc. That might be handy if you ever need a bearing. If you have a 3 point disc, you could use one of the snap couple 3 point thingys.
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 1:13pm
I have just the hitch for the disc that utilized the pully and chain to accomplish the weight transfer.  The chain is gone as I recall, but if someone wants the rest, $25 plus freight will get it on its way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 2:34pm
mine are the solid ones.  I forgot that they made the ones with the chain and sheave
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2011 at 8:22am
 Thanks for the rplies. A friend of mine has the solid hitch but the end the implement hooks to has something missing. We didn't know if there would be any intrest in something like this or how rare it was. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2011 at 9:40am
there should just be a piece of pipe stood up at the end and welded on this is where the tongue of the  disc would hook to and be able to pivot side to side .  if you have a drawbar mounted pull type you have to take the front tongue off the disc to attach it to the tb drawbar
