Just another dumb question |
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35695 |
Topic: Just another dumb questionPosted: 20 Mar 2011 at 8:32pm |
I have been looking around again at older loaders, thought I found a HD4 with a backhoe attachment but it left three days before I could catch it. Are one of these or a similar unit tracked loader/backhoe worth the having?
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42272 |
Posted: 21 Mar 2011 at 9:22am |
for your own work are OK but for woking out not the best. Unless you have a trailer and tow viehicle big enough to transport kind of static unit, where a TLB can least be driven to a site.
My AC 715 will do everything and and a little more than my HD4 with hoe could do. Only place where the 4 worked good was in demolition as no flat tires. Edited by Coke-in-MN - 21 Mar 2011 at 9:23am |
Posted: 21 Mar 2011 at 3:46pm |
Thanks, I may move more attention to backhoes.
Ages Cat
Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 700 |
Posted: 21 Mar 2011 at 5:07pm |
No such thing as a dumb question. It would be dumber not to ask.
Posted: 21 Mar 2011 at 8:08pm |
I am going to need to set roadbed first, then a foundation at some point. When I have these and the barn done then work on a house foundation. I already have my 180 with a loader for little cleanups, I just need a workhorse for the bigger deeper real digs.
Kipn
Joined: 12 Sep 2009 Location: Tewksbury, Ma Points: 800 |
Posted: 22 Mar 2011 at 9:56am |
Idealy it sounds like you'll want several diffrent machines. Realisticly you want to pay for one. After building a couple of houses, I finally bought a 580 Case to help with the 3rd one. Generally I figured it wouldn't do any job effectively but it would do all the jobs. That was 10 yrs ago. House is up and all is well. And if I wanted to, I could sell the 580 for what I paid for it. But won't. The worst job it does is grading, to light in the front.
1961 H3
Coke-in-MN
Posted: 22 Mar 2011 at 11:46am |
My AC 715 calls for 500# weight in front to balance the Dig-More extenda-hoe I have on machine but so far unless I am traveling on road it isnt needed if careful. Fluid tires on front might do the trick if and when I change them.
The TLB will do a lot more than a 180 as it is built to load, dig and is built for construction work. Have used it to level gravel, smooth landscape work, and dig basements, footings, and septic systems as well as hauling fill for driveways.
Posted: 22 Mar 2011 at 4:32pm |
I had kind of figured on the heavier machine to do the rough work, finish grade with my rear blade on the 180 then spread the rock as best as can tailgate and again finish with my 180. The bigger jobs will be for a true loader or backhoe and I will not even consider a tag on hoe for the three point, seen a few really messed up trying to be industrious with them.
I have a 9' drag blade(cough gag) JD 88 but it works good, I have a Farm Pro post hole digger attachment and of course the 500 loader on the tractor. If I could come up with a decent track loader that isn't a monster for the money or that the tracks were not absolutely trashed, that would do for a time but footer excavation will call for a hoe. I was maybe asking for more than I can actually get out of a single machine. I also intend to build a lake or large pond in time, maybe 20' deep at levee, 4+ acres in water surface, one can generally find old 4 yard LaPlant Choate pans pretty cheap around here and a track could pull that fairly well. |
Coke-in-MN
Posted: 22 Mar 2011 at 5:00pm |
A TLB works great on footings but I must have doug 20 basements with my HD5G and did frost footings for buildings with it also .
For pulling a scraper you had better find a lage 4WD tractor or a crawler bigger than HD4 and something that has cable or hyd to run the scraper.
A 4 A pond is a large area and guess if digging to 20' I would be looking for a excavator and something for haul if much distance.
Posted: 22 Mar 2011 at 5:37pm |
Will be scraping the sides out on a branch bottom, there is a real good place on our new place to establish around a 4-5 acre lake by dragging off the sides and stockpiling to a levee, has drainage from three major points and a spring. Doing some calcs with a bud, he thought there should be plenty of spoil as we clean up the sides to build a 20' tall near to 90' long levee and really not effect the base lay of land.
I will keep in mind for a bigger machine. |
Coke-in-MN
Posted: 22 Mar 2011 at 5:47pm |
and sounds like unless you do it a little at a time you could be creating a earthen dam and my run into problems down line with DNR, as well as other liability problems.
I dug a small spot in back for black dirt supply and then graded it off for a pond area 70' around and 6' deep , it holds runoff from surrounding area and also kept the area from ponding by my shop.
last year county was out saying they wanted to check my wetlands site as it showed up on satalite pictures as pond and wetland and under control of watershed.
Kind of explained a little but they said as it had cattails growing in area it meant it was wetland and county controlled now.
Posted: 22 Mar 2011 at 6:39pm |
Our DNR actually sites earthen dam ponds, suggests the size overflow and best or better systems for overflows; they have already been out for inspection and Okey-dokeyd the site I picked out, it was by their suggestion to no greater than 20' dam height.
Coke-in-MN
Posted: 22 Mar 2011 at 7:56pm |
might look at doing some reinforcing and be sure to put in spillway with good rip-rap so as to control erosion if and when .
I did one about 2 acres in size when i was done building a dike across low area , dike was 20' high and I dug another 10' in depth behind it to get material for it , took me about a week to build it and told guy I had working with me to park machine above top of dike height. We finished on a Thursday night and i picked up machine on Friday morning , and it was raining out lightly , that night the area flooded full and over dike taking out about 3' trench on one side . Rest held and still has 15' or more water in it all the time now 20 years later. Did install a culvert and rip rap to control drainage at about 18' height a few years later. Edited by Coke-in-MN - 22 Mar 2011 at 7:57pm |
Posted: 22 Mar 2011 at 8:11pm |
The gal from the DNR recommended I put in 2 four foot concrete pipe overflows, kind of like a regular storm drain stack to a minimum three foot outflow pipes, was also suggested to install them into the inside wall of the levee at around three feet short of the top of a relief spillway, a spillway is required should these develop blockage or be overwhelmed, she showed a overlay on a topo map as to the best approach for that too. Specs list for materials is lengthy but has to be met to gain permit to build and to keep once completed.
They also require a 'torturous' path at the outflow pipes to minimize erosion issue, large concrete blocks to divert and slow the outflow water speed set to a length of thirty feet out from the end of pipes. |
Posted: 22 Mar 2011 at 8:13pm |
Almost forgot, rip-rap spillway has to end to shot rock at the bottom, also to slow outflow speed; pricey for the build but it will get done to specs or better.
Coke-in-MN
Posted: 22 Mar 2011 at 10:52pm |
Over time it is funny how construction has changed where pan scraper was the means of most building now a excavator and haul trucks have replaced them. Articulated 20 or 30 yard haulers or such used for large jobs.
Just worked this summer on large site for new Target store near me and only for hauling in material was most things moved by dump truck, just about all on-site work was done with Volvo haulers. Spent 3 weeks or more there hauling in material from surrounding pits or borrow sites as well as rip-rap for holding ponds on site.
Skid-steers have replaced traxcavators, track hoes do many jobs now that other machines did but still the dozer is needed for finish or much work.
Posted: 26 Mar 2011 at 10:06am |
Coke, I have sent a PM as to this:
http://stlouis.craigslist.org/grd/2260984000.html |
Coke-in-MN
Posted: 26 Mar 2011 at 11:02am |
If it is a working machine shure will outwork any HD4 and would get a lot more use. then looking on another site it mentioned the trany as one area to watch,
Posted: 27 Mar 2011 at 4:18pm |
I got beat out of the 7G anyway, the gal I spoke to on it just sent me a e-mail, someone from PA is coming to get it, at least according to her, she was giving me one last shot at it on a first come sale.
I did find out no forward and noisy in reverse, got it to start once in the last six months but it died from water in fuel, they did not try to clear it before winter so it is probably scrap as to the fuel system. Edited by DMiller - 27 Mar 2011 at 4:19pm |
