sleeve seals
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Topic: sleeve seals
    Posted: 19 Mar 2011 at 8:51pm
How do you put sleeve in without ruining them on a c or b allis? I've done it before by just lube them up w/ vaseline. Twist them a little, tap a little & they went in. Today I messed up two of them , so I quit for tonite.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 8:53pm
Wow I'm talking about the O-rings, not the sleeves themself.
Joe/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe/NC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 8:56pm
Most of the time, seals get messed up like that when there is a "burr" or something in the way.  Make sure all is clean and clear. Maybe the seal is the wrong size, packaged wrong?
And some days things don't go well when I get tired and in a hurry. Tomorrow it might fit right together!
Good luck!
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 9:03pm
Can also try assembling with vegetable oil.  It won't cause the o-rings to swell up like petroleum based lubricants can.
Hurst
1979 Allis Chalmers 7000
5800 Hours
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 12:58pm
Hurst is right on, don`t use petrolium based lube on the o-rings
Pullin With AC
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 1:28pm
You may have to tight of a fit. You need to have enough clearance to drop the sleeve down in the hole and turn it 360 degrees with one hand. The O ring must have some clearance/space to keep from shearing off part of it. The bottom hole needs to have a slight chamfer to let the O ring start to enter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 1:48pm
I remember having to run a rabbit turd hone on the sleeve seal areas on my CA engine to get rid of rust, burrs, and proper fit like Dick says. 15 years later it's still going strong...
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 1:52pm
Yeah,don't forget to "dry fit "them first.If it won't drop in and spin freely you got some more cleaning to do.My 45 block had small champfer leading to bores.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 2:28pm
I have used dish soap as the lube for them, the groove where they seal needs to be cleaned out very well, I use a small wire wheel attached to a small air grinder then wash them out good with some brake cleaner.
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 2:31pm
We had some once that were made too big and would not fit! The first two tore up and we quit. Turns out they were for a stock sleve and not the eighth inch overbore. Got the right ones and they pressed right in
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 7:47am
thanks guys for all the advise. left the project a few days & things went alot better. I have to get new o-rings for the cycl that got ruuined . I used the veg oil & they tapped right in(with no pieces of O-ring left peeled off) . will do the other when I get the new O-rings.
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 8:48am
you guys dont suggest vasaline on the o-rings? i am getting close to putting the engine back together on the wd45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 9:12am
I used veg oil on my D262 sleeve o-rings. Vaseline is petroleum based. I'd use veg oil if I were you. Not saying Vaseline won't work, but the ordinary veg oil works very well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 9:13am
My wife has a tube of stuff in her night stand that works wonders to get the O ring seals to slip in place. It is water based.
If you get black greese on the tube don't put it back in the drawer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 9:45am
So is there now a tube in both the night stand and the tool box? LOL
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 12:11pm
that's that kentucky jelly I've heard so much about! Ain't very good on toast! LOL!
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 2:16pm
When I rebuilt my WD45 Distillate, I put the new sleeves in the freezer over night and they went in much easier.  Hard to get the wife to agree to that if they aren't spotless, but then these were new and I did not tell her.  I used the freezer in the garage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 3:02pm
Freezing them would help by giving you a wider gap for the O ring to enter but if you (can not) turn them (freely) all the way down with the O rings off and freeze them to get them in you (take a chance) of cracking the top sleeve ring/lip when you torque the head down. This is when you find one side of the sleeve higher above the deck than the other side. Cast iron sleeves do not flex much.
 Freezing is for installing (dry sleeves) and people get mixed up between the two when they have not been around both and tend to give bad advise. I am baffled at how many people I run across that do not know what a wet sleeved engine means. A GM trained mechanic that had worked on cars for many years was totally in disbelief that my 1923 Chevy had shimmed rod bearings that had the shims were between the rods and caps.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 3:08pm
Now I know why my wife has taken an interest in working on trctors! LOL
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 3:13pm
Ya' know, I was going to respond to Dick's post about that, but I just saw me getting me in trouble! LOL
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 3:53pm
I don't know why I'm not offended because I really should be. I let you in on a little (secret) and I bet it is being shared with everyone.  It's only a secret if you keep it to yourselves yaknow. Ya go telling your wives and they will be looking thru their night stands for greasy finger prints.
This page was generated in 0.056 seconds.
