Penetrating oils |
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3915 |
Topic: Penetrating oilsPosted: 20 Mar 2011 at 3:33pm |
I've known about this and have been using it for a while and have seen reference to it before. The results are interesting.
Machinist's Workshop did a test of penetrating oils where they measured the force required in a standard test to loosen rusty test devices. The results reported were interesting. The lower the number of pounds the better. Mighty interesting results for acetone and automatic transmission fluid! Penetrating oil . Average load .. Price per fluid ounce None ............ ..... 516 pounds . WD-40 ............ .. 238 pounds .. $0.25 PB Blaster ......... 214 pounds .. $0.35 Liquid Wrench ... 127 pounds .. $0.21 Kano Kroil ........ 106 pounds .. $0.75 ATF-Acetone mix.. 53 pounds .. $0.10 The ATF-Acetone mix was a 50/50 mix (1 to 1 ratio) _________________________________ John Kallend Professor and Associate Dean Armour College of Engineering, IIT |
TMiller/NC
Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1776 |
Posted: 20 Mar 2011 at 3:44pm |
We used Kano Kroil for years in an industrial environment with great results. I had not heard of the transmission fluid and acetone mix until a couple of years ago. It is an interesting result that the cheapest is the best penetrant. Tim
48AC/WD
Posted: 20 Mar 2011 at 3:47pm |
Looks like the parts store just lost me, lol going to have to try that ATF and Acetone mix, I use ATF in my partswasher to neutralize the bite a little bit, I use "Purple Power" in it, if you put that stuff in straight, it will eat the paint outta the tank, ask me how i know and why my filter was plugged with paint slime, LOL! The stuff is incredible though! |
48AC/WD
Posted: 20 Mar 2011 at 3:51pm |
Darn computer double posted, sorry guys. Edited by 48AC/WD - 20 Mar 2011 at 4:03pm |
Dnoym N. S. Can.
Posted: 20 Mar 2011 at 4:01pm |
ATF-Acetone 50/50 mix
been use-ding it to free stuff up it work i don`t think that the acetone will eat metal because it come in a steel can i free up 2 engine this winter with it and have not started them yet took 2 to 4 week to free them up rock them once a week let set till next week and rock again now i can turn them over with crank and i did suggested it a couple of time`s WD-40 . 238 pounds never cared for this one PB Blaster 214 pounds smell to much JMHO B:-) Dnoym |
Alberta Phil
Posted: 20 Mar 2011 at 4:09pm |
I've got an old Twin City parts tractor sitting out back that had been stuck for years. I loaded the cylinders with the 50/50 mix before Christmas and it freed up this week and just rolls over nice on the crank now.
