corn planter mid mount ca |
Dan SC ![]() Bronze Level ![]() Joined: 19 Mar 2011 Location: conway,SC Points: 13 |
![]() ![]() ![]() ![]() ![]() Posted: 19 Mar 2011 at 2:56pm |
FloydKS ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: S E Kansas Points: 7989 |
and the answer is...................
Need some help iding planters mounted on ca
wkpoor ![]() Orange Level ![]() Joined: 25 Apr 2010 Location: Amanda, OH Points: 825 |
I have one. And its one of only 2 I have ever seen. Was lucky enough to find it here on this forum.......Thanks Larry!!!
I'm looking for the model # of these planters. they mount on the torque housing and drive off of the rear tires. Fert and seed hoppers are 18" to 24" high. need help
MODEL # ????????? Can anybody help on ID
JimWenigOH ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: NC Ohio Points: 1153 |
Dan, I believe what you have is a "Side Dresser Attachment" that mounts on the CA cultivator. and was used to apply fertilizer to the crop while cultivating. I have the manual showing it mounted that way. The manual is Allis-Chalmers Form TM-54.
Dan, Check out eBay item 180631934886. It is a manual for a Mid Mount Planter for the WD tractor.
Its a little more than that a side dress has only on hopper as far as I know. But I have only seen one of this in pictures. The one is fert. but the other is for seed. they are both the same height. where I got said his G-dad used it to plant corn and cotton but he knew no more about it.
The post on ebay looks close but will it still drive off the rear axles on a wd???????????
I learned something today! I didn't know a "Front Mounted Planter" was made for the CA. I got to looking through my manuals and found the "Dealers Parts Catalog" for it. It has the parts listing for the A-C B, CA, and WD Front Mount Planters and Side Dressers. The WD also drives off the rear wheel. To answer your origional ID question, this planter as far as I can see is simply listed as the "CA Planter". You can buy the Parts Manual, Form D-16 at eBay number 300447000803. |
I said in my post that I have one Jim. Only one 2 I have ever seen. There was a guy in Texas last yr trying to sell a tractor with one on it. I wanted it real bad but Texas in along way from Ohio and it would have cost more to get than it was worth.
Dan, Its simply called a Front Mount Planter, no model # just like the Rear Mounted Planter has no number also. |
thanks everyone for your help!!!!!!!! I think I got the answer I was looking for.
Murph-NC ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Western NC Points: 797 |
Dan, did you happen to get those in NC? I've seen a similar listing on CL, just didn't occur to me what it was.
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
No got them from Anderson S.C.
