Help with WD dashboard
AFChap View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AFChap Quote  Post ReplyReply Direct Link To This Post Topic: Help with WD dashboard
    Posted: 12 Mar 2011 at 8:13pm
This is the dashboard for my 1950 WD. Can anyone tell me what goes in the center position? It was removed when I bought the tractor. Many Thanks!
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2011 at 8:16pm
I think the light switch goes there.  If the left one is a kill switch, the center is lights.
AaronSEIA
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2011 at 8:26pm
  kill switch goes in that hole
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2011 at 8:40pm
Your Light switch is in the correct place. That hole would have the magneto switch. If you had a distributor then you should have a key switch on the bottom left corner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AFChap Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2011 at 9:53pm
Thanks guys! Now I just need to find a kill switch and a wiring diagram.   :-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2011 at 11:22pm
If your generator has been disconnected, read this page before you start the tractor up.
http://dueyschutter.freeservers.com/photo5.html
Wiring for the mag is a wire from the post on the mag to a grounded switch. When the mag is grounded, the tractor is dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2011 at 1:34am
That looks similar to the one on my 1941 WC. I guess there wasn't much difference.
