1956 WD-45 ??????????????
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Topic: 1956 WD-45 ??????????????
    Posted: 03 Mar 2011 at 7:33pm
i have a 45 motor ??? about my filters it looks dif lol and im not sure about them lol ill post a video
ok here it is so please tell me if u no what or anything about this
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 7:40pm
Not going to be much help here, just bumping you back up. Doesn't look factory to me. Tractor probably was a diesel to begin with, but may have had that swapped in when the original went toes-up.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 7:45pm
The left hand frame rail looks to have the factory depression to accomodate the bosch psb pump, but the oil filter is definitely not right nor is the cut out in the frame rail to accomodate it.  the factory buda 230 engine had two oil filters but there was no cutout in the frame rails.  Not sure what engine that is, but it is not the correct one.
The 15th Annual Exclusive AC Swap Meet will be held in Boonville, MO, March 6-7, 2026. See the club website for details: http://www.moacclub.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 7:50pm
its a buda AC engine, the guy said it was put on there like  kit (but idk ) and i no he cut the fram to put it in i dont care if its not factory but as long as its good and works lol
but its not a bad tractor to have when ur 17 lol
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 8:25pm
Well the filter looks to be that of the early D-17 diesels, so it may be a 262, but with the bosch pump i don't know, because the 17's had the Roosa Master.  May be out of a combine too, hard to say for sure.
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 9:23pm
I was thinking that that engine may be out of a Cockshutt 40 which had the Buda diesel but not the same filter setup
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 10:01pm
looks like a D19/D17 diesel block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 12:35am
I would bet a guy could arrange a double filter set-up and patch the frame rail so you couldn't tell it from original.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 6:56am
I'll second that.
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 7:31am
well how much HP was a 40 cause the guy was pulling with it and she'll turn the rpm and is pretty strong
