|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| 53 CA starting issues... |
| Post Reply   |
| 53allisca   Bronze Level   Joined: 27 Feb 2011 Points: 2 |  Post Options  Thanks(0)  Quote  Reply  Topic: 53 CA starting issues... Posted: 27 Feb 2011 at 4:51pm |
| Hello, Needing some help... My 53 ca will not start, not even with a jump. Is there more than one fuse on this machine. I found the one that is in the ammeter box and it is not blown. All battery cables appear to be tight and clean. The starter would at least attempt to roll over or click with low battery, but will not even do anything even with quick jump from charged 12v battery. What could i be missing?? Thanks in advance for you suggestions. | |
| RyanTN   Orange Level   Joined: 12 Sep 2009 Location: Stewart Co, TN Points: 415 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Feb 2011 at 5:15pm |
| I would suggest tracing the starter circuit and carefully check each connection. I can post a wiring diagram if you need one. Especially check your ground and contacts inside the switch (on top of the starter). I bet you will find a corroded or rusty connection somewhere.   I am assuming that you have checked the battery with a voltmeter and it shows in excess of six volts.   I am not sure what you mean about "more than one fuse".  It sounds like there may have been some modifications over the years.  The only thing I can think of on a 53 CA in the ammeter box that would look like a fuse would be the resister for lights/charging system.   Six volt systems require much more amperage than 12 volt systems.  Amps are carried through good, clean connections and heavy gage wire.  I usually use water as an analogy: You can get water out of a both a drinking straw and a fire hose, so just because you may read 6 volts on a voltmeter (you have water), the connection may not carry the necessary amps to spin everything (you don't have the necessary flow).    Good luck!  Ryan Edited by RyanTN - 27 Feb 2011 at 5:17pm | |
| Walker   Orange Level Access     Joined: 12 Sep 2009 Location: oh Points: 8995 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Feb 2011 at 5:30pm |
   Hook the hot side of the 12 volt battery to the starter post. Then touch the neg. side of a jumper wire to the starter body. That ought to tell ya if the starter is working or not. Unhook the tractor battery first.
| 53allisca   Bronze Level   Joined: 27 Feb 2011 Points: 2 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Feb 2011 at 5:34pm |
   Thanks for the advice Ryan,  thats where i will start.  With the starter.   The connections are old,  but just had been gone over by a mechanic friend this past summer.  I didnt even think of the switch on the starter itself.   i will let you know what i find.
| CTuckerNWIL   Orange Level     Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Feb 2011 at 6:15pm |
look like a fuse would be the resister for lights/charging system. Ryan, If you don't have fuse on your light switch, yours is the one that is altered. | |
     http://www.ae-ta.com  Lena 1935 WC12xxx, Willie 1951 CA6xx Dad bought new, 1954WD45 PS, 1960 D17 NF | |
| RyanTN   Orange Level   Joined: 12 Sep 2009 Location: Stewart Co, TN Points: 415 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Feb 2011 at 6:24pm |
| Yeah either that or, more likely, my memory isn't as good as I like to think it is! LOL-- A quick look does in fact reveal a fuse on the light switch, sorry that I wrong/remembered incorrectly. Of course, this should have no bearing on his starting issue, and I cannot think of multiple fuses in the B/C/CA wiring diagram.  I stand corrected, thanks Charlie. | |
| Pipe   Silver Level   Joined: 12 Sep 2009 Location: Mi Points: 140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Feb 2011 at 6:32pm |
    I had a dead cell on a 6 volt battery and even with the quick start she would not roll . new Battery did the job.
| CTuckerNWIL   Orange Level     Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Feb 2011 at 7:27pm |
   53CA, either the switch on the starter is bad or you don't have a good connection somewhere. Connections include the contact points of the starter to the block. Sometimes people paint a tractor in pieces and get paint on things that don't need it, like the starter where it contacts the housing.
| Eldon (WA)   Orange Level     Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Feb 2011 at 7:50pm |
   Will it start with the hand crank?
     ALLIS EXPRESS! This year: | |
| Dave(inMA)   Orange Level   Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Feb 2011 at 8:22pm |
   Hmmm - any chance that the starter is jammed in the ring gear? I'd do as suggested above and pull the starter. While you have it out, test it with cables from a known good battery. If it turns over smartly, then work through the starting circuit. There's very little involved in spinning the engine with the starter: battery, cables, starter switch and starter. You can change out the battery; clean/tighten the cables; jump over the switch; test starter as above. Good luck!
     WC, CA, D14, WD45
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
