batteries for 7040
NYREDPOWER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NYREDPOWER Quote  Post ReplyReply Direct Link To This Post Topic: batteries for 7040
    Posted: 17 Feb 2011 at 6:49pm
My 7040 finnaly has arrived . The first of many small issues to solve are a set of new batterys. Can someone give me the CCA that I need Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2011 at 6:54pm
Biggest is bestest...1000 CCA for two batteries not four.
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2011 at 6:59pm
Just put two 1000 CCA in my bosses 7000 this morning, I am a firm believer that you can't have to much battery.
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2011 at 7:11pm
 I just got 2 850cca batterys for my 7060. The more battery the better but if you run 4 of them instead of 2 it costs twice as much to replace them when the time comes.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 10:39am
My 7060 has 2 1150 amp batteries.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 12:06pm
I run 2 1000 CCA batteries.
Wink
I am a Russian Bot
sandylakeimplement View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandylakeimplement Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 12:24pm
Original issue was Group 29H with a rating of only 660 CCA. 2 were standard, 4 was the cold climate upgrade option.  Bill
Sandy Lake Implement
Sandy Lake, PA
724-376-2489
www.sandylakeimp.com
FIND US ON FACEBOOK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 1:15pm
So one 1000 CCA is almost equal to the original equipment, wow I was thinking two 1000 CCA was only a little better than factory.
Edited by Denis in MI - 18 Feb 2011 at 1:18pm
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 8:23pm
Got 4 950 CCA batteries on my 7080
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 9:51pm
I,ve heard if you dont have enough battery power it,ll ruin the starter ? Would have thought it,d take more than 2- 650 amp batterys  from the factory but maybe not
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 10:15pm
I have 4 750CCA in my 7060, 4 700CCA in my 7040, and 2 850CCA in my 7080. The 7060 will start at 0 all by itself, the 7040 (with atleast 8year old batteries and 9300 original hours) will start at 35 by itself, and the 7080 will start at 40 by itself (fresh motor and old batteries). Dr Allis bigger is not always better with batteries, the more CCA you get outa the same size batteries will not last. They make the plates thinner and they will not hold up to the vibration of the tractor. Dad has a WD45 and would always put 850-1000CCA batteries in it, they wouldnt last  but about 2 years. Hes put 650CCAs in it and they have lasted close to 10 years. The battery man suggested going with lower CCA for longevity. The thicker plates will hold up better.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 11:28pm
I have 850cca walmart batterys in my 7060 and I would like to switch to another brand but they have me trapped with 3 year free replacement. I just took both my june 09 batterys in and had them replaced.
This page was generated in 0.176 seconds.
