39 B tool box ?
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: 39 B tool box ?
    Posted: 07 Feb 2011 at 8:30pm
Am making a new tool box (no battery style) and got it mostly finished but cannot decide which way the inner braces turn.   Are the flat sides up or down?
Different question.............why is the square sheet metal on the steering tube?  Tim
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 8:39pm
On all the '39 s I bought, the flat was up, not down.
I thought the square part made a good place to stick the crank in....
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 9:03pm
On the early B's the brackets were turned up and the gas tank layed on them There was a piece if 1/8" thick piece of canvas  webbing that laid between the strap and the gas tank to prevent the two from rubbing metal to metal. The square on the steel tube was to hold the crank. There was a spring clip mounted below the tube to keep the crank from bouncing around. Bob
This page was generated in 0.091 seconds.
