Need some snowblower help |
Mercury45
Topic: Need some snowblower helpPosted: 22 Jan 2011 at 4:06pm |
Hello all... I am new here and I plan on sticking around as long as I can get my allisChalmers sno bee 7 cracking again...
here are some pics http://s376.photobucket.com/albums/oo206/mercury45/Snobee%20Snowblower/ Also a video.... http://www.youtube.com/watch?v=MUHtkLOmugc The parts i neeeed is the large impeller / auger pully (9 inch sheve) with 7/8" hold and keyway and I also need the bearing for the back of the impeller the one that was supposed to be there was totally gone does anybody know where to get these things... anybody have a manual with part numbers they can check for me, ill pay pal you some money for checking into it if i have to thanks in advance kenny |
Mercury45
Posted: 22 Jan 2011 at 4:10pm |
Sorry gang, I forgot to put the numbers in here
I know its an older allischamlers sno bee 7 (7 hp) model - sno bee Serial # 7-001356 thanks, Kenny |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42106 |
Posted: 22 Jan 2011 at 4:15pm |
Unsure of your location .. many farm supply stores cary sheaves (pulleys) with weld in center that is pre-bored to shaft size you need . As for bearing you may be able to use a pillow block flange mount bearing also that you can get at same store.
kip in cny
Joined: 29 Nov 2009 Location: Jordan NY Points: 538 |
Posted: 22 Jan 2011 at 4:17pm |
the pulley and key stock and bearing you should be able to get them from the local farm store the impeller that may be tricky
160 CA 920diesel 5020 HD-3
Mercury45
Posted: 22 Jan 2011 at 4:44pm |
i just need the pulley and the impeller bearing, nothing else.... in my pics i still have the flange for the impeller bearingmaybe i should look for a bearing that fits in it? I'm very new at all this please pardon my ignorance....
I am in NJ when you say farm store, I tried a loca... power equipment place but he did not have what i needed.... ill try tractor supply maybe but i do not know if they will have it either.... |
Coke-in-MN
Posted: 22 Jan 2011 at 8:11pm |
Your pictures or video do not come up for me . TSC might have it or a bearing supply house , industrial supply place would have it also can try WW Granger or McMaster Carr, both should have a online catalog you can check.
Mercury45
Posted: 22 Jan 2011 at 8:27pm |
thanks coke---- those websites work for me i just copy n paste to url bar
Coke-in-MN
Posted: 22 Jan 2011 at 9:35pm |
dang brouser Bing or whatever would not work with it .. got it now.
Sheave should be no problen finding as it is stamped steel and most farm stores will have them and the weld in center. The bearing are what are called light duty with pressed steel flange , if the steel isnt worn then the incert (bearing assembly) can just be replaced but full 3 bolt unit might be best to buy. As they are set screw lick to shaft it looks like might want to go back to same , but other style locking divices are also out there.
That is one problem with the light duty bearings they can't be serviced , just replaced. Unsure if you have room but might look at another type bearing housing that allows greasing bearings.
Edited by Coke-in-MN - 22 Jan 2011 at 9:45pm |
Mercury45
Posted: 22 Jan 2011 at 9:48pm |
thanks coke ill take a look... seems most of the bearings are 2 or 4 bolt, but ill keep looking for 3 bolt.... as for serviceable - not a big deal... if it lasted 40 years the first time, if i get 2 years out of it ill be overjoyed.
thanks - kenny |
Coke-in-MN
Posted: 22 Jan 2011 at 10:14pm |
At a bearing house or even farm store many times they have just the insert, try McMaster Carr also and I just looked quick but in some cases the bearing can be removed from a 2 or 4 bolt flange and put into other housing like yours.
