Question 5bolt to 6bolt Hub Conversion |
Zyta ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: Ontario Points: 238 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Jan 2011 at 12:56pm |
Anyone know if the hubs off a smaller AC combine will switch over onto the WD-45 front spindles/axles to move you from a 5bolt to a 6bolt hub & Rim. |
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4515 |
I don't have the answer but the later D-15's and D-17's had 6 bolt hubs.
Maybe a 6 bolt from a D-15 will work. There has been this discussion on here before. If I remember correctly the outer bearing on a 6 bolt hub is larger. You could always take your spindle to Eldale in Elmira and they will fix you up with a 6 bolt hub.
John WV ![]() Silver Level ![]() ![]() Joined: 30 Oct 2010 Location: bunker hill wv Points: 273 |
small ac combine has brass bushing not bearing in hub |
Calvin, do you have anything apart over there to compare with?
Kip-Utah ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Southern Utah Points: 856 |
D17s were made with both 5 & 6 bolt hubs, but I dont know if they used the same spindles if they do, I'm sure a D17 hub would work on a WD45.
HANSEN'S OLD ORANGE IRON. Showing, Pulling, & Going!!
Lester ![]() Orange Level ![]() Joined: 08 Jan 2010 Location: Indiana Points: 518 |
I have 1959 D-17 with AC pull combine hubs and a195745D with 6bolt WC hubs on.
Dave in il ![]() Orange Level ![]() ![]() Joined: 22 Sep 2009 Location: Manville Il Points: 1748 |
My 58 D17 has 6 bolt hubs from a 190, had to find different outer bearings.
allisorange ![]() Silver Level ![]() ![]() Joined: 27 Mar 2010 Location: perkins, michig Points: 375 |
We have 6 bolt hubs off a junked model 100 combine.
John Carlson
