190XT front weights
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Topic: 190XT front weights
    Posted: Yesterday at 11:59am
I looked at a 190XT yesterday that has suitcase weights on the front. I think it is the first time I have seen them on a 190XT. Was it an option, is it aftermarket, or were they available on a later tracyor and someone has put them on this? I didn't get great pictures of the mount, but it looks like it was made for the tractor. The serial number is in the early 11000 range in case anyone wants to know.
Ted
190XTD seriesIII, 190XTD seriesI, maroon belly 7000, 7045, 190XTD series??? project(or maybe parts)
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 12:45pm
"Looks" like the bracket and weights from a 200. The bracket would bolt right on the XT
Leon B Mo
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 1:28pm
What is that powercrater engine decal all about on the grill? Nice looking grill too.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 9 minutes ago at 2:51pm
I noticed the power crater sticker. Owner wasn't home so I didn't hear it run or drive it. It looks clean and straight, obviously been repainted. Has series III stickers on it too, so maybe the owner just bought a bunch of Allis stickers. My brother is thinking about getting it, if we look at it again we'll probably take a trailer in case it runs okay and stays in gear. It also has pie weights. All the weight along with 18.4-38 rears(and duals) makes me a little nervous about the running gear but maybe it has been updated.
Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 41 minutes ago at 4:19pm
Is it a gasser? If yes, that may explain the power-crator sticker. The grill, rear pie weights, front weights and 38 duals are worth quite a bit. 11xxx sn makes it a 1966, like me. Can't see much from pics but if the rest of the tractor is as clean as what I see, it would be hard to pass up if the price is right.
Leon B Mo
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 33 minutes ago at 5:27pm
It is a diesel, it is clean. I can see a few spots that have had some oil buildup, mainly hydraulic pump and couplers. Probably nothing major on the pump, and needs to have the 60 year old couplers replaced. It looks like whoever did the front weights wanted it to look nice, so probably anything else that was done is going to be correct. Funny thing about the 38s, if we get this one it will be three of them with 38s.
If we get it I will get some better pictures up.
Ted
Edited by TedN - 19 hours 32 minutes ago at 5:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 30 minutes ago at 8:30pm
See how it steers, should be able to turn the steering wheel with one finger. Take it for a drive, 3rd gear, lock the left brake and turn the wheel hard left first in low range a full circle then switch to high range. Do the same to the right. If it surges as it turns then that’s a possible problem in the pump if all fluid levels are full. This also test the brakes. This is how I figured out that I had pump issues and it required a full rebuild. Verified later with gauges but this is good field test. I do like the front weight set up.
Edited by AC720Man - 16 hours 27 minutes ago at 8:33pm
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 27 minutes ago at 6:33am
You better get that thing bought before it gets away.....
Edited by IBWD MIke - 6 hours 27 minutes ago at 6:33am
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 60 minutes ago at 10:00am
I don't think suitcase weights were an option for any One-Ninety's or XT's.  As Leon said, probably from a 200.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 48 minutes ago at 10:12am
In that 1972 year range and newer, the 200-210-220's all had those 65 lbs suitcase weights available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 5 minutes ago at 12:55pm
If the bracket is from a 200, it will have 6 or so square holes behind the weights to put the locks in for various numbers of weights. There's to many weights on there now to use locks. They look similar to the locks on a 70xx. 200's also offered a different bracket that accepted the 175-185 style weights. We had 2 200's, one with each style.
Leon B Mo
