8550 turbo elbows |
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8778 |
Topic: 8550 turbo elbowsPosted: 3 hours 7 minutes ago at 8:13am |
I need new turbo elbows for my 8550. Old ones have corroded and eroded to paper thin. Part numbers are 70259236 and 70259238. Agco parts books says check with dealer for availability. I'm guessing that probably means my local dealer (butler) does not have them, but could check other dealers. Thought that I would put it on here first in case someone on here has changed them and knows what hoops to jump through to get them. Thanks
Darrel |
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3645 |
Posted: 1 hour 23 minutes ago at 9:57am |
Have your dealer call vintage parts 877 846 8243 . Agco moves slow moving items to them from time to time. No dealers show stock. The turbos were TO4B90's similar to 7060's. Might use some of the diffusers used elsewhere and modify if you can't locate OEM's.
Edited by tbran - 1 hour 2 minutes ago at 10:18am |
