Batteries, Unggh! |
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35610 |
Topic: Batteries, Unggh!Posted: Yesterday at 5:19am |
Recycled Crap, best have gotten is Five years in the 180 at minimal use, just changed the unit in the 2010 Impala, made 4 years 1 month since last swap.
KW will need 4 before vacation to Black Hills this summer, are just coming to Four years. Same for our motorcycle. Changed those in my Pickup two years back and the one in Wife’s car last year. Sellers note the recycled junk will only carry a One Year to at most Two year warranty, are NO lead cell batteries being made with Fresh Lead, some are concerned recycling is not separating materials clean enough. NOT Buying a Li Any blend battery for the vehicles, notable fire hazards. |
Codger
Posted: Yesterday at 7:00am |
I'm giving a couple of AGM types usage now in the dozer. Had several sets make 10+ years in standby generator service before retiring. Wet cells didn't last all that long with the chassis mounted battery racks so went AGM and they seemed to tolerate it well.
That's All Folks!
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25210 |
Posted: Yesterday at 7:04am |
battery life went downhill once they eliminated the caps. With no way to check electrolyte levels and high powered alternators, it's a death sentence. High charge rates can 'boil' off the acid and water., just a little at a time but once it's gone, it's GONE.Seems it only takes '5 years' and time for a new battery.
Posted: Yesterday at 7:07am |
Our Harley has a AGM, lasted longer than the standards, those would only go two years, this one three. As of the last purchase priced a AGM for the Chevy, could not stomach the price, over $240 even as typical Lead Acid was $170, Group 31s in the semi and the 180 will remain Lead Acid for now as well as replacement AGMs double the cost and not the life.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12418 |
Thanks(1)
Posted: Yesterday at 7:46am |
Replaced a tractor battery last fall that was 10 years old. Just pulled two out of a different tractor 9 years old. Not bad for the cold we get.
Codger
Thanks(1)
Posted: Yesterday at 7:49am |
I went the $$$ for the AGM in the dozer solely based on the vibration factor. I keep nearly everything on maintainers any longer and the life seems to do fairly well. I have a single 4D series in an International semi tractor used for a yard horse and it replaces four group 31 series and it does well also.
I tend to not care too much about lables and if the cells are accessible they are checked periodically. Always distilled water, or sulfuric acid if top off is required. I have a "Leica" refractometer for solution specific gravity evaluation and it works well being much more accurate than the floating balls, or swinging needle type testers.
That's All Folks!
Posted: 15 hours 56 minutes ago at 3:24pm |
First Group 31s I installed new in the 180 went 8 years, the next set just over four, this set should make another two.
Joined: 11 Sep 2009 Location: illinois Points: 90676 |
Posted: 15 hours 43 minutes ago at 3:37pm |
I replaced the F150 and Edge batteries at 6 years... Still working, but i dont trust them for winter use.. Buy most at Wal Mart 3 year type.. Have bought a couple at local Hardware or Farm Store with similar life.. I do put a trickle charge on the ones that set all winter..
Codger
Posted: 1 hour 19 minutes ago at 6:01am |
I trended batteries for a lot of years when maintaining/repairing standby generator sets, so continue the trend into retirement. I have a 1000A carbon pile for the purpose and use it routinely. A battery that is getting short on lifespan will readily reveal itself with one of these.
We were mandated to replace starting batteries on a four year rotation whether they tested good or not. All the systems I worked with backed up aviation navigation equipment so they really did need to start when commercial power failed...... Seen a lot of starting batteries work very well until the first cold snap of the year comes forth in automobiles then not start the vehicle. A carbon pile load test readily reveals this oncoming failure prior to it stranding anyone if it's done.
That's All Folks!
