Found a 6080 |
Acguywill
Joined: 15 Jan 2024 Location: Vauxhall ab Can Points: 198 |
Topic: Found a 6080Posted: 21 hours 57 minutes ago at 12:43am |
Well we finally got one. Late model (deutz-allis stickers) with fwa cab and loader. Everything seems to work and it looks pretty good for a 40 year old tractor with 8000 hours on it. But I do have a question about the hydraulics. It has a homebuilt grapple on the loader controlled by what looks like a third factory hydraulic lever. Located on the right side of the seat and operated by pulling up or pushing down on it. Only 2 sets of couplers at the rear of the tractor, this is plumbed in somewhere under the cab. Is that factory or a dealer installed option or is it a custom deal?
cornel b
Posted: 12 hours 8 minutes ago at 10:32am |
6080 had a third remote option. maybe they just ran the hoses forward
4w-305 7040 6080 6060
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3642 |
Posted: 8 hours 60 minutes ago at 1:40pm |
Even though it is a late model - I would check the fore/aft play on the crankshaft. The late 4.33 motors had a double wide thrust - BUT, at high hours I would still check it. The front bearing set up can still be added. Congrats and just my 2 cents worth.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5458 |
Posted: 2 hours 2 minutes ago at 8:38pm |
I’m guessing a bearing support from a donor tractor? NLA from AGCO the last time I checked, we wanted to add one to our 6060.
Acguywill
Posted: 1 hour 25 minutes ago at 9:15pm |
Thanks for that. I looked it up on tractor data and it said 2 remotes. I have never seen one with a third remote before so I would guess it isn't very common? |
