new truck question |
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25202 |
Topic: new truck questionPosted: 3 hours 31 minutes ago at 6:31am |
curious.... if you have the radio set 'kinda high' then shut of the truck, when you restart the truck does the radio come on 'kinda high' ,low volume or not at all ?
Joined: 11 Sep 2009 Location: illinois Points: 90638 |
Posted: 1 hour 43 minutes ago at 8:19am |
on my 2013 F150 .... radio , heater, blower motor all come back at the same spot where you left it. ... same on 2019 FLEX.
Edited by steve(ill) - 1 hour 42 minutes ago at 8:20am |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12410 |
Posted: 1 hour 5 minutes ago at 8:57am |
Seems like I have encountered one vehicle either of my own or somewhere in the extended family at some point that if the radio was left on it came on at a default volume…..seems a long time ago and no clue what vehicle it was.
Posted: 34 minutes ago at 9:28am |
well... this is what GOOGLE said....
2024 Ford F-150 owners report that the radio volume often resets to a default level (typically around 7) upon starting the truck, regardless of the volume setting when it was turned off. This behavior is a common complaint, often attributed to Sync 4 software updates and appears to be a consistent issue rather than a rare fault. For the 2023 Chevy truck (Silverado/Colorado), the radio volume is intended to remain at the same level as when the engine was turned off, but in practice, many users experience issues where it defaults, resets, or goes silent upon startup.
Edited by steve(ill) - 30 minutes ago at 9:32am |
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8399 |
Posted: 27 minutes ago at 9:35am |
Our ‘95 Suburban had a feature that would automatically adjust the sound system volume to compensate for road noise. It was a dial that sat behind the volume button, you could adjust that dial to increase/decrease that feature.
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25535 |
Posted: 22 minutes ago at 9:40am |
FWIW, my 24 Silverado remains where set
it is standard radio system Edited by LouSWPA - 21 minutes ago at 9:41am |
I am still confident of this;
Posted: 17 minutes ago at 9:45am |
my wife's 1019 Nissan stays where it was , LOUD,as she plays it LOUD. I get in to move it ,start, then 3-5 seconds later get BLASTED ! 1-0 doesn't shut radio off volume control is useless for a few seconds. HATE starting it up... yeah, old and cranky BUT it's a safety concern. NO WAY should the radio come on,let alone BLARING.....
