Looking for Hd6 part |
Jgriffis03
Topic: Looking for Hd6 partPosted: 18 Mar 2026 at 9:42pm |
I’m needing the intermediate shifting shaft. If anyone has one for sale I would greatly appreciate it. Number 5 on the callout for parts diagram of the shift tower. Thank you in advance
Codger
Posted: Yesterday at 7:20am |
Have made that exact part a couple of times in the past. 4140, or 4340 Alloy steel will offer enough surface "toughness" without heat treat to last. Have a machinist bore the shift handle, (#6) round and bush this with oilight bronze, or drill and tap your new shaft, (pivot pin) for a grease zerk, and cross drill for grease path keeping it tended to. While the shift lever is out always a good idea to have the lands where the pivot screws butt against cleaned up also. Makes for a nice tight shifter again as long as the shifting forks and shafts are in good condition. These always need touched up also as wear items.
That's All Folks!
Mikez
Posted: Yesterday at 9:31am |
What’s the part number
Jgriffis03
Posted: Yesterday at 9:45am |
I’m sorry all, it’s number 6 on the callout.
P/N: 098089 Or P/N: 086705 It’s the whole lower shaft |
Jgriffis03
Posted: Yesterday at 9:46am |
The whole shift lever is missing haha. My issue is that I’m not sure I can get one machined without precise measurements of one first.
Les Kerf
Posted: Yesterday at 3:07pm |
Maybe check with General Gear and Machine in Boise, Idaho
Codger
Posted: Yesterday at 5:35pm |
Definitely be cheaper to obtain used, but I can make one if needed.
That's All Folks!
Jgriffis03
Posted: Yesterday at 9:20pm |
How much would you charge for one?
Jgriffis03
Posted: Yesterday at 9:59pm |
I checked there and they said the one they had they just threw out because it was worn out
Les Kerf
Posted: 22 hours 28 minutes ago at 11:15pm |
Forum member gemdozer has some parts but he said his yard is closed until Spring, also, he is in Canada
Codger
Posted: 17 hours 34 minutes ago at 4:09am |
No real idea as time and materials would be in play. Realistically probably $350 - $400 is in the ballpark. I have a good piece/pattern to follow. Have never made one complete as you need but have rebuilt several.
Before putting much into this tractor I'd suggest you manually get into each gear and operate it. You can do this by moving the shift forks with a pry. Seen a lot of 'Starry Eyed" auction, and sale purchases over the years reveal underlying buget busting problems underneath requiring wheelbarrows rather than shovelfulls of money to fill the pit. Edited by Codger - 16 hours 49 minutes ago at 4:54am |
That's All Folks!
Jgriffis03
Posted: 12 hours 27 minutes ago at 9:16am |
Little back story here, it was parked up about 40 years ago and I bought it for 600 bucks and I honestly didn’t have the equipment to pull it out of there so as the mechanic I am I got it running an drove it out of the hole it was stuck in. The only thing I need to do now is replace some hydraulic lines and free up steering clutches. I did try and shift in all the gears hand itinerary shifts pretty smooth and they all grab
gemdozer
Posted: 8 hours 38 minutes ago at 1:05pm |
I should have this lever shift and I could check late next week
Jgriffis03
Posted: 7 hours 44 minutes ago at 1:59pm |
Yeah I’d sure appreciate it. Really out of options at this point
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42254 |
Posted: 7 hours 4 minutes ago at 2:39pm |
Dont have the parts list handy - is that the part that fits into shift tower and has shift lever clamp to it ?
The part that actually moves the shift rails in trany - ball type end and , pivot point center and round shaft through shift boot |
Jgriffis03
Posted: 6 hours 51 minutes ago at 2:52pm |
Yes, its the lower shaft that actually sit inside the transmission and has a big oval hole through it which is where the bushing goes. I will see if i can add a picture
Jgriffis03
Posted: 6 hours 50 minutes ago at 2:53pm |
Les Kerf
Posted: 6 hours 29 minutes ago at 3:14pm |
My PDF version of the HD5/6 transmission parts book shows that as being called the "LEVER, shift" and is P/N 7086705. I put about 40 hours into rebuilding that part on my Son-in-laws HD5G, mostly by brazing and hand filing; I documented it on a thread several years ago. It would be quite a challenge to fabricate one from scratch. The intermediate shaft is something else entirely. Best wishes on your project
Codger
Posted: 3 hours 58 minutes ago at 5:45pm |
Hopefully Gemdozer has what you need to get you going. Glad you know the trans and finals are good. Seen plenty that haven't been so happy once they break into them.
That's All Folks!
