Back to the KW!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Back to the KW!!
    Posted: 14 Mar 2026 at 12:27pm
Was having Engine Fan(Air operated) issues, would Stay on, fail to disengage.  Then would partially disengage and the Bypass controls would not function.  Looked to all the controls and a air solenoid that is easily changed where thought had it, then repeated again.  Finally Caught the Hub seals in Failure, when disengaged the air to release would leak out past the Clutch Faces.
Only a Slight Blood Letting during the wrestling match, Hub is over 45 lbs, hangs of four 1.2" fasteners, Horton and common.
Had to use a Sling from over top to pull it out of engine area,  almost two hours of Joy!
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2026 at 10:03pm
they are HEAVY and awkward to handle
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2026 at 7:20am
Luckily they last at average 100,000+miles.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2026 at 10:14am
Used to easily source kits for rebuild, or exchange units readily available. Still so?
I have a "Huber" reversing fan on the 11-B tractor needing service, but it's mechanical and frozen in place. No parts available for those any longer I've found.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2026 at 11:04am
Reman thru Horton still prominent so is on the way.  Kit was over $400, complete assembly with Warranty $650, Exch.  Need a at least 20t Shop press and three Specialty tools for the Horton series, Not worth the hassle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2026 at 4:22pm
Replacement arrived, instead of Tapered head clutch area is flat to pulley face, newer style. Is a direct replacement HOWEVER as Stock rotated Price raised, added $300 so just under a grand.
Cannot move photos off damn old phone, jack connection will not mate to download to PC to adjust. So this phone is crap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2026 at 10:12pm
Think the last one I rebuilt was about $70.00 for the kit which included seals, bearings, and retaining rings. Can't remember but think the friction surfaces were there also and it was an OEM Horton kit. That was for a 3406 B, or C Caterpillar engine but a Cummins NTC-400 was near the same price. Never have worked on anything newer.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 11 minutes ago at 6:54pm
Repair parts for the older are scarce, unless NOS in some suppliers shelves as tge Horton hubs have been Changed so too Obsolescence.
Friction now Flat not conical, front face alloy with steel pulley, piston and seals changed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 32 minutes ago at 6:33am
Photos, FINALLY!
Sitting on 5Gal bucket.
Prior to reinstall.  Used 1/2" Polyester Rope in a figure 8 Harness pattern, from Frontal no pulley area to rear belt region to drop in from Top.  Two Studs barely visible in Photo are lower mount hole fasteners.
Edited by DMiller - 7 hours 22 minutes ago at 6:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 28 minutes ago at 7:37am
They must still be heavy. That was the hardest part; the encumbrances, and dead weight hanging. Used to have two guys with a 2X4 over shoulders to support the weight and another guiding/running the fasteners. Haven't done one in a while now but the gantry, forklift, or skid steer comes into play for any of that lifting any longer.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 52 minutes ago at 11:13am
Laid across Intake tubing, Used a 1/2" polyester Figure Eight Rope 'Sling' with a loop in final knot as a Handle, lowered down by hand to the Studs from Above engine nose and started nuts there, then added bolts.  About two hours calculating and removing that which needed to come off, about hour and half to reinstall.  Just under 50lbs.
Edited by DMiller - 2 hours 52 minutes ago at 11:13am
This page was generated in 0.250 seconds.
