HD 11 |
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 716 |
Topic: HD 11Posted: 02 Mar 2026 at 5:01pm |
Is it possible to buy sprockets for a HD11
1984 80780
AC Mel
Posted: 03 Mar 2026 at 10:23am |
Should be able to find some...there are 2 different choices based on serial number.....do you know which one you are looking for?
8070nc
Posted: 03 Mar 2026 at 1:19pm |
No sir. I havent seen it in person yet. The guy that is selling it says the sprockets are still usable but will need changing soon. All this came up all of a sudden. Ive got 55 acres id like to clear to put cows on. Maybe a few acres tilled. Its got some wet spots so ive got to ask soil conservation if i can even do it
1984 80780
AC Mel
Posted: 04 Mar 2026 at 9:37am |
Copy that....well if and when you get some pictures and post them we could tell which sprocket you need.
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8965 |
Thanks(1)
Posted: 13 Mar 2026 at 7:42pm |
...if the sprockets are that bad,how do you think the pins and bushings are let alone the rails?
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35558 |
Posted: 16 Mar 2026 at 8:50am |
Major Problem is will need to change All or None to make it any viable. Several have gone to locating 955 or D6 Sprocket rings or Segments and then changing out Rollers and that means redrilling frames, Idler can be revamped to accept 6.91 Cat rails where those will then outlive the machine. Are NO 7.0 pitch rails available US any longer.
Codger
Posted: 1 hour 35 minutes ago at 5:39pm |
Don't be discouraging; great fun and exercise to be had rolling track back on that's walked off.
That's All Folks!
Les Kerf
Posted: 49 minutes ago at 6:25pm |
Yup. BTDT. Lots of quality family time to be had when that happens!
Posted: 34 minutes ago at 6:40pm |
Did often on the 7g until swapped rails from that donor.
