Looking for Hd6 part |
Jgriffis03
Joined: 19 hours 16 minutes ago Location: Iowa Points: 4 |
Topic: Looking for Hd6 partPosted: 19 hours 8 minutes ago at 9:42pm |
I’m needing the intermediate shifting shaft. If anyone has one for sale I would greatly appreciate it. Number 5 on the callout for parts diagram of the shift tower. Thank you in advance
Codger
Posted: 9 hours 30 minutes ago at 7:20am |
Have made that exact part a couple of times in the past. 4140, or 4340 Alloy steel will offer enough surface "toughness" without heat treat to last. Have a machinist bore the shift handle, (#6) round and bush this with oilight bronze, or drill and tap your new shaft, (pivot pin) for a grease zerk, and cross drill for grease path keeping it tended to. While the shift lever is out always a good idea to have the lands where the pivot screws butt against cleaned up also. Makes for a nice tight shifter again as long as the shifting forks and shafts are in good condition. These always need touched up also as wear items.
That's All Folks!
Mikez
Posted: 7 hours 19 minutes ago at 9:31am |
What’s the part number
Jgriffis03
Posted: 7 hours 5 minutes ago at 9:45am |
I’m sorry all, it’s number 6 on the callout.
P/N: 098089 Or P/N: 086705 It’s the whole lower shaft |
Jgriffis03
Posted: 7 hours 4 minutes ago at 9:46am |
The whole shift lever is missing haha. My issue is that I’m not sure I can get one machined without precise measurements of one first.
Les Kerf
Posted: 1 hour 43 minutes ago at 3:07pm |
Maybe check with General Gear and Machine in Boise, Idaho
